Question about Amana Kitchen Ranges
Oven will not light - Amana Kitchen Ranges
  • 205 Answers
Hello. If this is a standard gas range the most likely problem is the oven ignitor. You should be able to pull either the bottom drawer or the oven pan out and see if you can see any glowing when you set the oven to Bake. If you don't see any glowing then it is probably the ignitor. If you are unsure of how to check the ignitor then I would call an Appliance Tech out to take a look. Hope this helps, best regards.
Posted on Sep 28, 2010
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
The bottom oven light and heat is on all the time can shut off
Faulty switch if Oven light has a switch, some ovens light stays on, some oven lights switch.off when door closed. As to Oven being on all time , Faulty Switch.
Mar 13, 2015 | Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Oven light stays on all the time even when oven off.
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Mar 22, 2014 | GE Monogram® ZET1PLSS Dual Single Oven
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Oven will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Kitchen Ranges Logo
253 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
