Dewalt 18 Volt Compact Drill Kit Logo
Anonymous Posted on Sep 28, 2010
Hi Rocco here My dc925 drill, i was using it and when i plugged in the fully charged battery, it all of a sudden started smocking. thick smoke, without even pulling the trigger. I immediately removed the battery but battery is burnt out. I tested the switch for a short but showed good. I plugged in the other battery and it stared to smoke also but i unplugged it quicker and battery still ok. what can be the problem?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
355
Points
Battery start smoking & get very hot as soon as put in drill 925dc
Light stays on
Doesn't that mean it's fully charged?
2answers
Why does my screw gun work an then stop and work again ?
The trigger is probably going bad. A replacement trigger is around $30.00
My DC 925, is destroying my batteries. the drill will run but quickly smokes the battery. I believe it may have something todo with the trigger and battery terminals... any help?!
sounds like there may be a short somewhere. Don't use it like this as overheating the batteries will ruin them. and they cost almost as much as the drill
2answers
Totaly dead ????
Thanks for stopping by.
Check the 18V battery with your multimeter to be sure it is fully charged.
If it is - the likely culprit is the trigger on the drill.
You can get Dewalt parts from eReplacementparts.com
If the battery is not charging - it could be an issue with the battery, or charger.
Thanks!
It has been intermittent for a while now like there was a loose connection somewhere. But the other day the battery started smoking so I had to remove it. It is around 3 years old
Take a look at this diagram. Items 14 and 15 are the wires that run from the switch to the motor. They tend to get hot and melt the insulation of the wire where the connector plugs into the motor. If the bare wire touches the metal motor housing then it will short out. I would guess that is what happened.
http://servicenet.dewalt.com/Products/Detail/DC925KA#pp-parts
1helpful
When do you know the battery is fully chaarged
on the charger there is a red LED that blinks while it is charging when it is fully charged it will not blink usually about 1 hour to charge a DeWalt 18v battery
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
2answers
Battery starts smoking when drill turned on leading to total batterie destruction . drill runs fine it is an 18v hammer drill one total battery loss one removed before it was destoyed.
it is unlikely that you had two defective batteries, it makes more sense that the charger is overcharging them. It would have to be checked with an amp meter to be sure
3helpful
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
