Question about KitchenAid Dishwashers
KITCHENAID KUDSO3FTSSO DISHWASHER WILL NOT COMPLETE CYCLE. STOPS NEAR END OF CYCLE AND THE START/RESUME BUTTON FLASHES. YOU HAVE TO MANUALLY HIT THE START/RESUME BUTTON TO COMPLETE CYCLE.
  • KitchenAid Master
  • 12,061 Answers
Https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d?OpenDocument
Hi, your problem is most likely a sensor or some sort of damage has been done to the main controller board, by a power spike etc.
What you need to do, is troubleshoot your issue to find the cause, accordingly, I have found you a service manual, so you can do this also I have included a DIY, website to assist you.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
If you do not wish to DIY, then it is my professional advise that you please call a Kitchen Aid service center and ask for an engineer to call and give you a "Quote" for the repair, this way you can then make an informed decision as to what to do.
Posted on Sep 28, 2010
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
Dishwasher is locked but the door is open start/resume light flashes continuously
shut the door and push the start/resume button and wait 5 min before doing anything else. if the start button is flashing that means the cycle was interupted in some way.
Apr 08, 2012 | Dishwashers
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
My dishwasher will not start its cycle
Is there power to the dishwasher?
electricity ground dishwasher.
Connect ground wire to green ground connector in terminal box.
Donot use an extension cord.
Failure to follow these instructions can result in death,fire,or electrical shock.
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
214 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
