Question about Fujitsu Heating & Cooling
Fujitsu inverter ASTA24LCC aircon wont work on heat mode. Two flashes of red and green lights, followed by five flashes of red light and sequence continues with a pause between. Other modes, fan, cool etc work.
  • Anonymous Mar 12, 2014
    fujitsu aircon asta24lcc will not start power is on
  • Anonymous Mar 30, 2014
    the a/c works, but the heat will not engage.
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
Fujitsu Aircon model AST24PBA-W has green Timer light continuously flashing and red Operation light giving 5 flashes. Outside unit fan will not run. What does this code indicate has failed?
Most likely a faulty fan motor. You will need a tech to diagnose correctly as this uses a DC motor which has a circuit board inside so has very specific tests. Other possible faults for this code are compressor rotation error, CT abnormal or current trip all of which will need a tech to diagnose.
Nov 04, 2017 | Fujitsu Heating & Cooling
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
the problem with the electronic ones is they usually need repairing by a service centre or aircon guy and if it's not under warranty they'll be able to recommend their repairer. We had a similar fault where there was just some random code error. It happened during a heat wave and it turned out the fan motor seized and the board got burnt out. They had to replace they board so that may be what you're up for.
Dec 14, 2014 | Fujitsu Heating & Cooling
Hi Ken,
I hope the following link will help you?
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Dec 13, 2014 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
May 14, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
1,688 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
