Question about Kenmore 13593 Stainless Steel Built-in Dishwasher
The dishwasher stops at the rinse cycle, does not drain and then the Quick Rinse button is the only cycle that will light up. Sometimes I can get the washer to choose a different cycle... but it is about every third day. And once the load gets to the rinse cycle, it starts all over again.
catriver
  • 878 Answers
SOURCE: Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Posted on Aug 28, 2006
catriver
  • 878 Answers
SOURCE: Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Posted on Nov 21, 2006
SOURCE: My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Posted on Nov 25, 2006
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
My dishwasher is starting it's cycle, then running for a minute or 2, then it stops and drains itself, then starts the cycle over and repeats this. It won't continue it's cycle and it seems to be stuck in...
you seem to be stuck in a 'quick rinse' cycle. double check your buttons as well as your timer/dial to see if you are using the normal wash cycle. especially check the buttons. good luck
Nov 02, 2009 | Frigidaire Dishwashers
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Blinking quick rinse and lock on lights
Try holding down the "lock" button.It may be the way to unlock the problem.
May 26, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Flashing quick rinse light on panel
I had the same problem but I found someone wh said that there is a way to reset the dishwasher. I tried it and it has worked so far.
Here is what I did.
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Oct 24, 2007 | Kenmore 15769 Built-in Dishwasher
Frigidaire dishwasher rinse cycle problem
problem just might be that not draining. when on drain, hold hose into a bucket about 3 feet off floor and check drain rate is good. if plumbed in under the sink, also check no blockage at the sink spigot
May 07, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Kenmore 13593 Stainless Steel Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
