Question about Whirlpool Dishwashers
F8 is flashing. The drainage well in the bottom of the machine is full of water, so much be blocked somewhere.
    Brigadier General:
  • 6,966 Answers
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your dishwasher with the primary function of keeping large particles of food and foreign objects away from the impeller/pump. Most current dishwashers have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other dishwashers need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher and may cause the problem as you have described.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned.
There are pages online with illustrative description and detailed procedures on how to go about this. Perhaps you can try referencing here and/or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 24, 2008
How can I stop my washing machine end indicator light coming on before cycle has finished?.
sound very much like you have a blocked pump or a drainage block. If your machine outlet is connected to a push on spike under the sink, remove it and check Its not blocked. If that is clear CAREFULLY remove the filter cap, Usually on the bottom righthand side of the Machine. I say carefully because if there is water in the Machine it will pour out and flood so do it a bit at a time till its empty. Check the filter it may be clogged up, if it is thats your problem if not it needs further investigating. time to call the repair man. By the way whilst you may have economy 7 I would never advise putting your machine on at night and going to bed if anything should go wrong you are not there to switch off, Ive seen some real nasty stuff over the years where machines have gone rogue unattended, it really isn't a good idea although Thousands would disagree.
Aug 03, 2014 | Tricity Bendix Washing Machines
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
I have a Bosch Nexxt 700 Series Washing Machine. We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash...
Is the pump pumping? Have you cleaned all the drain lines including the discharge hose? You may have nothing in the pump but it could be blocked somewhere else.
Apr 24, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Maytag front loading washer will not drain...
there could be a few issues, either the evacuation pump is not working or getting power to pump the water out. or the drainage pipe is blocked.
there is also a filter in the bottom of the machine that could be blocked
check the filter is clear, if you remove it be prepaired for a lot of water coming out. check the drainage hose to ensure it is not folded or blocked.
I hope this was useful.
Feb 15, 2013 | Maytag MAH6700A Neptune High Efficiency...
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine. Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor. pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards. If the pump is too old or worn out then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
DE code flashing on my Lg dishwasher (model 2131).
Hi, it seems you have a drainage problem. Try to reset the machine, or start a new cycle. It should start draining straight away. If not, listen carefully to see if the dishwasher is making a huming noise. If it is then the waste pump is blocked. If not it might need a replacement pump.
Feb 12, 2009 | LG Dishwashers
Pool of water from freezer.
The likely cause is the drainage outlet is blocked by dirt deposits or frozen ice behind the plastic panel inside the freezer compartmrnt. Melted ice overflows the tray insteady of being discharged through the tray's drainage outlet tube.
To check if the tray drainage hole is blocked, it is easy to take off the plastic panel inside the freezer compartment by undoing the six small screws.
Please don't forget to switch off the electric before you attempt to clean the blockage. Good Luck
Apr 08, 2008 | Zanussi ZEBF262W Bottom Freezer...
Dishwashers Logo
164 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
