Question about Microwave Ovens
My MCD1311ST Magic Chef Microwave Oven went off. Turned on the main fuse that had turned off. Clock and light now unctioning. For heating, 30 seconds registers on the clock and counts down to zero but heat, fan and turntable do not function. What is wrong please?
  • Microwave Ovens Master
  • 17,129 Answers
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step dwon suppy, the pads are responding- if not fauty pads- or the door switches ,if contact is not through the microwave willnot work.
Now keeping clear of the microwave, switch on , use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Posted on Sep 28, 2010
Think my fuse blowed
Generally, Microwave ovens have a glass fuse on the main filter board inside the microwave itself. Attempting to replace this yourself (opening the microwave covers) is not advisable. There are several components inside a microwave oven that run at 2000-3000 volts and though it is unlikely, there is a chance the capacitor on the high voltage side is still charged and presents a LETHAL hazard. A repair of this nature should be referred to a qualified technician.
Sep 05, 2013 | Magic Chef MCD1311ST Microwave Oven
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
No heat on magic chef microwave
Check the door safety interlock switches.
Dec 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Cana I download an instruction manual for the MCD1311ST?
Go to this link to get your user manual:
http://www.devicemanuals.com/guide/Microwave%20Oven/Magic%20Chef/Magic-Chef-Microwave-Oven-CT-MCD1311ST-Instruction-==TVRJek16UTU=.html
When you get there, scroll down and enter the validation code.
Then on the next page, scroll down and click on Download Now.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 17, 2009 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD1311ST, no longer heats. Any suggestions?
Probably a bad magnetron tube. If you dont hear that tell tell buzz when it is running then that is a good indication of a bad mag tube.
Jul 29, 2009 | Magic Chef MCD1311ST Microwave Oven
Resetting clcok on Microwave Oven..
I have a Magic Chef microwave oven, The model # is MCD1311ST.
After I reset the clock when daylight savings time ended, it displays 1:00 PM as 13:00, 2:00 PM as 14:00, etc. How do I get it back on a 12/12 cycle instead?
Warren.
Nov 08, 2008 | Magic Chef Microwave Ovens
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
