Question about Lasko 5520 Ceramic Compact Heater
The heater is less than two years old and it blows cold air, and not heat!
  • 17,130 Answers
Make sure with a multimeter that the heater is having the continuity and the switch is contacting correctly . If so the heater must work.
If not the coil can be faulty or the switch can be defective.
Posted on Sep 28, 2010
    New Friend:
I would say that your elements are burned out in your heater.. I would go and buy a new heater..Would not chance trying to fix that one and something else go wrong and it catch fire.
Posted on Apr 25, 2013
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
Vauxhall combo heater not working
Coolant is the carrier heat.
Top off the coolant system and test heater setting.
If the coolant and thermostat is over 2 years old then you should do a coolant flush.
Jan 15, 2014 | Cars & Trucks
The blower fan comes on several minutes before the
Bad fan switch. It may also be called a fan limit switch. If your furnace is less than 5 years old, the switch is part of the circuit board and you will need to replace the board.
Jan 11, 2010 | Heating & Cooling
After switching from heating to cooling - air won't come on
It sounds like the fan relay in the stat itself is not closing when you make the switch over. If you have had the stat for less then 5 years it is covered. Honeywell has a full 5 year warranty on their focus pro stats, and would replace it free of charge.
Apr 02, 2009 | Honeywell Focus 6300B 5-2 Days...
Car only blows cold air
Check temperature heath controltemperature heather controlNTREPID Temperature/Heater Control 2000
Dec 04, 2008 | 2000 Dodge Intrepid
My dryer is just blowing cold air, it is not heating. It is less than a year old. We just moved and it is not working now?
call whatever brand it is and have them send somebody out there. if its less than a year old its underwarrenty
Aug 05, 2008 | Whirlpool Dryers
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Unit blows cold air instead of warm (burrrr)
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Nov 23, 2007 | Amana PTC153B50AJ Electric Heat Air...
Lasko 5520 Ceramic Compact Heater Logo
624 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
