Question about Dishwashers
My dishwasher wont turn on when start is pressed. It wont fill. We have checked all connections and it is plugged in. We got it to work about 5 times by using the reset code but it never would start to fill by pushing the start button. We have tried many things and nothing is working.
  • 17,130 Answers
It seems that the control board is faulty as there is no reponse to the panel even with all checks. So if the power seems right , ther fault can be the program controller.
Please check the motor wiring, the pump and connections once again before the board can be changed.
Posted on Sep 28, 2010
Testimonial: "changed out the "mother-board" with an old machine I still had out back in the shed. It fit perfectly and the machine now runs great. viva la red-neck"
Maytag dishwasher wont fill with water
Hi Mingsten 1) check the water valve under the sink make sure it is open. 2) check if the water line is pinched or twisted 3) if you have a meter you can check if you get power to the dishwashers water valve ( it is under the dishwasher. behind the kick plate.) you will have to remove 2 or 4 screws to get to it. hook up your meter and close the door. wait for the pump out and check for 110-120 volts when the dishwasher should fill.. 3) if you have power at this time you will need a need dishwaher water valve.. 4) if you get no power then you may have other problems ( let me know and we can go deeper) I hope this helps let me know...
Sep 29, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
My dishwasher will not start its cycle
Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Is there power to the dishwasher?
electricity ground dishwasher.
Connect ground wire to green ground connector in terminal box.
Donot use an extension cord.
Failure to follow these instructions can result in death,fire,or electrical shock.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
My model number is FDB1500LFSO, my dishwasher quit...
Is there power to the dishwasher? Electricaly ground dishwasher. Connect ground wire to green ground connector in terminal box. Do not use an extension cord. Failure to follow these instructions can result in death,fire or electric shock.
Why would my dishwasher not fill?
Check the following:
Make sure the water is turned on to the dishwasher
When you press the start switch, you should hear a "click" which is the water valve opening - if no click, you should check the water fill valve. Remove the lower front cover and find the valve with a water line connected to it. It should be about 3/8" flex or copper line. These valves can malfunction over time and they can also get clogged. You can check for clogging by turning off the water and removing the line to the valve. Check for debris. Use a shallow pan to catch the water so you don't get it all over the floor.
If you don't hear a click when you start the machine, it could also be the control board, although the water valve is more likely to be the issue.
Jul 03, 2009 | Electrolux Kenmore 24 in. Built-In...
Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
402 people viewed this question
Top Dishwashers Experts
