Question about Samsung Propel A767 Cell Phone
My samsung propel soft keys aren't working. I was thinking of taking it apart to try to see if it needs cleaning. Is that what I need to do, and if so, how do i take it apart to get to the keys? Thanks
  • Samsung Master
  • 17,130 Answers
You will have to remove the front panel to remove the board, use the required cell phone service tool so as not to damage the set.
A cleaning might help but cannot be confirmed until it is done. If not take a consensus with a service dealer to confirm/estimate , check with error codes.
Posted on Sep 28, 2010
  • dkoalabear10 Sep 28, 2010
    thank you. most appreciate
There is a red line through one of my contacts and when that person calls, it goes right to voicemail without ringing
Give this a try:
  1. From the standby screen, press the right soft key for Menu
  2. Select Address Book (8)
  3. Select Reject List (5)
  4. Highlight the desired entry, using the navigation keys
  5. Press the left soft key for Options
  6. Select Delete (2)
  7. Choose Selected (1)
  8. Press the left soft key for Yes to confirm the deletion of the Reject List entry
Jun 28, 2011 | Samsung Propel A767 Cell Phone
Dishwasher won't drain
There could be something blocking the drain. Perhaps some food or something else. You might need someone to take it apart to clean it out if you aren't able to do it yourself. I think it is under the dishwasher behind the lower panel.
Feb 26, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
I took my Samsung Propel into the shower as to not disrupt a conversation via text. I think it might have gotten some steam and/or water in it. Now some of my keys take a few presses to write a letter and...
You need to immediately unasseble it. take off battery cover, take out battery and if possible use a hairdryer on the inside of the phone (obviously not too close to the phone hardware). Then leave it for a couple of hours and if you're lucky enough, it will work as it did before the steamy shower!
Feb 06, 2011 | Samsung Propel A767 Cell Phone
I need to take my samsung sgh a767 apart.
You probably need to pry off the front faceplate and look for screws beneath it.
Apr 15, 2010 | Samsung Propel SGH-a767 Cell Phone
Left and right soft keys won't work
Try CPR in NYC. They usually have a one week turnaround time, and are pretty cost effective. You can easily ship them your unit.
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | Samsung Propel A767 Cell Phone
I have a samsaunge propel and i cant get someone off reject list
It is just easy...
Mar 25, 2010 | Samsung Propel A767 Cell Phone
I dont recive messages my signal bar is gray insted of white please help
try this steps if it will work
  2. Select Settings (9)
  3. Select Phone (4)
  4. Select Airplane Mode (6)
  5. Highlight either On or Off, using the navigation keys
  6. Press the left soft key for Select to save the Airplane Mode setting
Mar 19, 2010 | Samsung Propel A767 Cell Phone
Samsung Propel A767 left and right soft keys not working
Hi I have the same problem and took it for repair, Its the flex cable, parte of the cable was broken and the area that was broken was the softkey area. It case me $40.00 to be repaired
Feb 15, 2010 | Samsung Cell Phones
I need to take apart the samsung propel to clean the keypad. Pop spilled on the phone..now the buttons are sticky. Can you help?
Yes I can help. You may not have to take it apart. If you buy PURE isopropyl alcohol, not like rubbing alcohol which may be only 70 pure, you can actually dip the whole phone in it and it won't be damaged. Inovagent offers this kind of service if you're near DC. The stuff to get is Iso-HEET from an auto parts store, which is pure. Good luck!
Nov 04, 2009 | Samsung Propel Cell Phone
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
Samsung Propel A767 Cell Phone Logo
833 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
