Question about Denon Audio Players & Recorders
Bought new AH-D2000 Denon headphones. Only used a week. One earphone came detached from the headset. Looked carefully, and discovered the screw came out. Have washer and screw, but the area to put the screw back in is too small for a screwdriver to get in -- would need an angled screwdriver. So I need to know if the earcup comes off the bracked to I can put it back together and tighten it.
This is an ongoing problem with Denons, if only your screw fell out like mine, you have to do the following to screw it back in properly.
1. You have to remove the ear cups from the head band part.
2. To do (1), you have to remove the styrofoam ear **** (the soft leather part) by press down on the soft part and rotating it counter-clockwise.
3. With the ear **** removed, you will see a total of 8 screws. 4 are flat and on a higher plane, and other 4 are inside holes. Unscrew the 4 that are bigger and on the higher plane. This will remove the plastic round back from the ear ****.
4. With the big round plastic part removed, you will now have the space to properly screw in the fallen screw.
5. Make sure to use Lock-tite to hold the screw in place so it doesn't fall out again.
Posted on May 18, 2009
  • ZarkovBeats Sep 12, 2010
    Ignore the previous post!
    There is a much easier way to fix them:
    Get a pin or small screwdriver and put it up the whole in the piece attached to the headband (not the cup).
    The little metal 'cap' should pop off if you push hard enough. under the cap will be a nut, 2 metal washers and a spring. I personally removed one of the 2 washers.
    Place the cup back in and simply tighten the nut around the screw that points upwards towards the headband.
    It may be hard to do this against the pressure of the spring, it took me about 10 minutes to finally get the nut to catch round the thread of the screw using my fingernails. I then used a pair of tweezers to tighten the nut. Because I removed one of the washers I could screw it on a little further than how it comes to avoid it coming off again.
I cannot connect my iPod nano with Bluetooth to my Denon AH-W150 bluetooth headphones. Help!
that is because the ipod nano can not connect to bluetooth it does not have a bluetooth reciver
Sep 07, 2013 | Denon AH-W150 Exercise Freaktm Bluetooth...
How to repai nokia wh 701 headset when only one earphone is working
Aug 17, 2012 | Nokia Genuine Wh-701 Handsfree Headset...
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
Is there anyway to repair the foam earpiece on denon ah-d210 over the ear headphones?
Have a look at my tip on headphone problems just click my user name to find it, you will find an answer at the bottom of it.
May 24, 2011 | Denon Audio Players & Recorders
Hi, I buy a new Plantronics Backbeat 903, but right now it's unrecognizable by any movile, can you give some hints on how to fix that problem. I try with an LG P500 and Nokia 6110, no answer...
Delete the device from the phone, then re-pair the headphones with the phone. If you just turn on the headphones, the device cannot connect because the headphones store the information that you already deleted it on the phone. To pair again with the other device (like a computer, phone, etc) you need to turn off the headphones, then turn on the headphones but press the power/pair button and hold until the led flashes red and blue (like 10 sec after the led turn only blue) to put it in discovery mode. Then turn on your phone and follow the instructions for finding (discovering) your bluetooth headset.
Good luck from Headsets Direct!
May 06, 2011 | Plantronics Backbeat 903 Bluetooth...
Can I replace plug on my Denon overear headphones
If the cord is broken at the plug, most standard sub-mini,mini phone plugs can be replaced by someone with a little skill at soldering ( a ohm meter also helps). Get a replacement stereo plug like the old one (often at Radio shack or any electronic parts store). Cut off the old plug and carefully strip off the outside insulation back about 1/4". Note there is 3 conductors. The webbing around the 2 wires goes to the outside back end of the plug. This is the ground or common wire for both sides. This wire may have a non conducting coating on it which needs to be stripped off before you solder it to the plug. There is 2 other wires in the cord. one (often red) is the right channel and the other is the left. You can check which channel is the right side with a meter or a AA battery. DON'T try to check with the earphones on your head!! The right 'hot' side will go to the tip of the plug and the left side goes to the ring next to the tip. Don't forget to strip off the insulation of the wires by gently scraping them with a sharp knife or razer blade. Also don't do like I sometimes do and forget to put the collar or back piece on the wire before you solder the wires on the plug. Hope this helps.
Dec 29, 2010 | Denon AH-D1001 Headphones
Only left earphone is working
You should return them to the place you bought them. They should be able to sought the problem out. You might need the sales ticket. Or visit the Bose website. They should have telephone number helpline.
Jul 09, 2010 | Bose QuietComfort® 15 Acoustic Noise...
The conection plug broke.
See if my tip on headphones will help you with this problem.
Apr 05, 2010 | Denon AH-C751K Headphones
Keeps clicking between speakers on and hp input on...no sound
had same problem with my denon 1910 .... clicking with no sound and some modes indicating not available. Blowing the dust out of the headphone jack solved the problem !!!!!!!!!!!!! ... the denon people could not even figure it out. Thanks sooooo much.
Dec 30, 2009 | Denon AVR-589 Receiver
846 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
