Question about Speed Queen Dryers
I have a Speed Queen model: HE7230L and it runs but will not heat. I could not find any reference to this model in your Q/A. I have checked the power breakers and they are fine. I assume it is the heating element or the thermal fuse. This is a very basic and older model. Do I follow the suggestions that are mentioned already or is there anything unique about this model that I should know. Many thanks.
  • damai554 Oct 02, 2010
    The info the website gave me on accessing the SpeedQueen was wrong. I had to open the whole dryer and remove everything to access the heating element. It turned out to be alright. I discovered a short circuit in the system that caused the problem with the dryer. I appreciate your response, but did not find anything there that was new to the Q and A that addressed the situation. Thanks anyway. Maybe another time.
  • Speed Queen Master
  • 43,501 Answers
As you have read there are basic problem solving ways to trouble shoot this dryer. Checking the heating element, thermal fuse and thermostat should give your the problem. An OHM meter is required to make those tests and one of them can be purchased for 20-30 bucks at any Walmart and many other stores...
The thermostat and fuse will have full continuity if good and the heating element will have resistance but will pas a current through it. Also check the heating element for any places where the coil could be touching when cool but pull apart when heating. Check for any broken or rubbed through wires also...
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 28, 2010
My speed queen dryer model #AES68AWF doesnt heat what could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Speed Queen AES68AWF Gas Dryers
My speed queen dryer (model 170) is over heating. Clothes are extremely hot to the touch and wrinkled.
check the dryer vent to make sure nothing is blocking it, Hot clothes and wetness is usually caused by venting problems,, if the moisture and air can't leave,, you end up with your problem
May 27, 2011 | Speed Queen Dryers
I have a speed queen electric dryer model number aem45300. problem the dryer runs but does not heat. We cleaned out all the area that contained lint. Is there a reset button for the heating element in...
There is no reset button, check yoru breaker, by turning FULLY OFF (somewhat forcefully off) then back on and test again.
All thermal limiters will auto reset when cooled...
Mar 04, 2011 | Speed Queen AES17AWF Electric Dryer
I have a speed queen gas dryer model number Aqm499w2 that will not heat up.
Better give technicians a call your problem seems the igniter is busted.
Nov 06, 2010 | Speed Queen AES68AWF Gas Dryers
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Mar 12, 2010 | Speed Queen Dryers
Dryers Logo
Top Speed Queen Dryers Experts
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
