Ti318 heater want come on, when switch from ac to heater ac keep blowing
    Problem Solver:
  • 8 Answers
Check switch and confirm the contacts are good.
Posted on Sep 28, 2010
2002 Chevy venture ac heater fan keeps blowing while van is off
You probably have a bad switch, Disconnect the wires from the switch. If it stops, replace the switch. If it doesn't, stop, you might have a stuck relay, or a short somewhere.
Sep 20, 2014 | 2002 Chevrolet Venture Passanger
Fuse keeps blowing on a/c on 2001 dodge truck
Let's break this down.
1 Does the fuse blow when the heater is on, or just the AC?
Yes- Fan motor problem likely need new blower motor.
No- 2
2 Disconnect the AC compressor clutch wire. Remove the blown AC fuse, connect a multimeter across the sockets for the fuse, measure DC voltage across the two sockets with the AC switch, and Ignition switch ON. Is Battery voltage present?
Yes- The wiring harness has a short between the output of the AC switch and ground, likely a pinched harness.
No- The AC compressor clutch is shorted. Replace either the whole compressor or the clutch.
Apr 01, 2014 | Dodge Ram 1500 Cars & Trucks
When i turn off my heater or AC the fan keeps blowing until I turn off the car
The fan blower will work independently of the ac switch but the ac will not work unless the blower fan is switched on. It is possible that you have been using the one switch to control both with out realising what is going on.
Sep 29, 2013 | 2006 Hyundai Tiburon
The air only blows out only on defrost on my 91 chevy truck
air blows out only defrost possible cause could be faulty ac and heater mode switch or broken vacuum line to ac and heater vacuum actuator.you have to remove ac and heater control switch to check it out.
Dec 05, 2011 | 1991 Chevrolet C1500
Can't shut off the heat
You didn't say which switch you were referring to. So, since you say the "heat" keeps blowing out, I asume that you do not mean the fan control only (which would simply indicate a faulty switch) but the "heater/AC temperature control". Check the vacuum lines (to heater and AC vent controls under hood first then under dash) for holes/cracks/breaks or if one may have come loose.
Jul 07, 2009 | 2002 Chevrolet TrailBlazer
AC and heater
does it go to cold after a while its ok if not there is a bad switch some were
Oct 23, 2008 | 2001 Nissan Sentra
Heater or ac fan does not blow, ac still cold, fuse where is it
Yes, but more likely the fan speed switch is defective or the blower is defective
Oct 20, 2008 | 2005 Chevrolet Suburban
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
