Question about Clarion DXZ745MP CD Player
I would like to knw how do i wire up the radio and what color is the power wire the color of the ground and the color of the memory wire and also the radio has two yellow wires how can i tell which one is it
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clarion Master
  • 2,226 Answers
Red is ignition (switched power), black is ground. yellow is constant. you need to use the larger yellow wire. the smaller yellow wire is for operating a changer.
Posted on Sep 28, 2010
Turn key off and removed. Power stays on radio ,heater.
Hello? It sems that the wiring is not done properly. Make sure that the radio wiring is done correctly. We have 3 wires that are very important when it comes to radio wiring. We have vcc,acc and ground. Vcc has to connect to battery direct, this helps keep radio memory on all the time. acc goes to acc and this switches radio on and off when you turn the key. Ground goes to earth. The wiring harness color code depends on different radio makes and car makes as well but a professional should help you with this.
Nov 16, 2016 | Cars & Trucks
Radio will not go off when key is off
It might be an after market radio. The wiring is deceptively simple. There is a memory wire(usually blue) that is supposed to have full time power from fuse box. What some people do with an after market radio, is wire the full time hot side of the radio, to the switched side. Witch causes your problem. To fix this issue, find your full time power behind the radio, and the switched power wire. They will have to be separated if they are connected. Your radio should have a wire diagram either on the radio or on the aftermarket wire harness. Various radios have different colors signifying wire codes. 2 things are certain; RED is hot BLACK is ground. Memory wires are either yellow, blue, or green. They should say what they are. In the bike side, you already know you have a full time hot wire. Now you have to locate the "SWITCHED" hot wire. To do this, grab a tester light, ground the clip on the frame, and check all of the wires that could be possible hots while turning the key off and on. Match all of your wires, button it up, and you shouldn't have any more issues. ^^ Good luck.
Apr 15, 2013 | 2005 Honda GL 1800 Gold Wing ABS
Color codes do not match my new radio can not get any power to the radio
Do these colors match your truck wire colors? Let me know if not or if you have more questions.
1991 Ford Ranger Pickup Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Oct 16, 2010 | 1991 Ford Ranger Supercab
I got a car stero with a cd player, the one I am taking out was
THe speaker wires from "new" radio will be in pairs ie;GREEN/ RED/ GREY / , They look like they are the same color but you will find a "tracer color" on one of the paired wires, ie plain GREEN / GREEN with a thin black stripe etc. The single Red will be Battery power the Orange will be Ign / accessory for the radio station memory. the other wires will vary but should be (possibly) panel illum/ power antenna/ aux power and ground wire . The radio will ground off the antenna connection .but should be connected at a later time . good luck .
May 03, 2010 | 1998 Chevrolet Lumina
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
2001 Ford E-150, year 2001, wire harness connection
As for the head units leads they should be marked or identified in the installation manual. There are but only three wires here that I might be able to help you with.
Two of the wires should have in-line fuse links (12+ volt power) and they are the constant feed (for memory) and the switched feed (for operation). The ground lead is typically solid black.
This is a general factory radio color code. Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
Good luck
Aduz
FORD P o w e r Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly) S p e a k e r s Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
Mar 28, 2009 | Car Audio & Video
Installing the car stereo
yellow=main power red=memory,constant power black ground and all the other colors are speker wires trial and error
Mar 22, 2009 | 1999 Chevrolet Prizm
Memory not working
blue yellow to yellow and gray to red should be right
Feb 01, 2009 | Pioneer DEH-2300 CD Player
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Clarion DXZ745MP CD Player Logo
181 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
