Question about Mitsubishi WT-42311 42" Rear Projection Television
Model WT - 42311. The television turns on, and then shuts off quickly. No error code noted.
  • 130 Answers
Hi seems that you have a shut down problem
caused by faulty power suply
Posted on Sep 28, 2010
When i press power the timer light flashes and the T.V. turns on and right back off.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Oct 03, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have A Wt-42311 Tv problem having is either by remote or switch to turn power on i switch it on starts up and shuts off in 3 to 4 seconds. simple fix or?
Mits sets give codes for different failures. By holding down the menu and device buttons on the front panel you can get a 2 digit code that will tell you what is wrong with the tv. The digits are seperated by pauses. 2 and 2 is common and points to a convergence failure. That's the simplest repair you can expect. Goodluck to you.
Jul 06, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
When I go to turn it on it clicks and then clicks off
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 15, 2009 | Mitsubishi WT-42311 42" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
My wt-42311 shuts off then comes back on after a few minutes.
ur power board ic inverter is about to die.
It will die sooner or later,when it dead.U get no
power period,must replace the board.
Aug 23, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
