Question about D-Link Computers & Internet
LAN how can add acess point into VLAN ,. here is my devices , 1. Netgear Switch FS726T 2. Access point netgear WGR614 please give me a solution anybody ?
  • 611 Answers
Wifi0] Chipset AR5413 802.11abg NIC (rev 01)
-- If -- Mode -- SSID --------------------------- Hide -- Security -
>> ETH02 AP Trusted Network no WPA-EAP
ETH03 AP Guest Network no Plaintext
[wifi1] Chipset AR5413 802.11abg NIC (rev 01)
COMMANDS
<N> New SSID <M> Modify SSID
<D> Delete SSID <I> Show Information
<C> Std/Channel/Tx-Power
<L> List Stations <S> Channel Scanning
<R> Restarting Devices <Q> Quit
Posted on Jun 05, 2008
Install new password on netgear wgr614 router
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 29, 2012 | NetGear WGR614 Wireless Router
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
Main router is a dlink, and it's connected to a netgear router as a slave, and i want to use the netgear router for wireless within the house
http://192.168.0.1
Jun 28, 2012 | NetGear WGR614 Wireless Router
How do i add aditional routers to gain access to the network from a detached shop using wireless
Connect your addition routers to NetGear WGR614 Wireless Router port ,Use NetGear WGR614 Wireless Router as a switch ....
Check if it works
Thanks
Snadeep
Mar 08, 2011 | NetGear WGR614 Wireless Router
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
Present a conflict with the ARP protocol between vmware server and netgear fs726t switcher
This being sensitive issue, I suggest you to log a complaint with NETGEAR. Visit my.netgear.com and raise a ticket with NETGEAR support.
Hope this helps.
Sep 24, 2009 | NetGear FS726T (FS726TNA) Transceiver
How to bypass netgear firewall
you should be able to log into your netgear device and adjust the settings. Open your web browser and point it to http://192.168.1.1 that should get you to the device. The default username is admin and the default password is password.
Aug 26, 2009 | Computers & Internet
How to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Jan 05, 2009 | NetGear WGR614 Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
262 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
