Question about MSI NF750-G55 AM3 NVIDIA nForce 750a SLI HDMI ATX AMD Motherboard
Will not power but everything is connected correctly
    President:
  • 1,768 Answers
Our issue sound as if the power supply has gone bad and a replacement is needed.
If you have all connection proper then there is no +12/-12/-5/+5 at the mother board.
Posted on Sep 28, 2010
07 ram. Clarion vz401 has blinking red light, thats it! Disconnected everything and checked fuses. Everything is fine. Will not power on no matter what i do
Hi Deli:
My suggestions:
- Use a voltmeter to confirm power supply
- Make sure power supply connected to correct wire.
- Confirm that unit is properly grounded. If ground wire, use continuity meter to confirm that ground wire is indeed grounded.
- make sure speakers are properly connected.
And last, but most important, Did the unit work before you tried to install it. There's not much fun in trying to make a dead unit entertain you.
Hope this helps.
Sep 08, 2015 | Computers & Internet
Can't get any sound from device, can't find a fuse in device, it powers on, but no sound.
Should be a fuse in the device. If not, the device wont even power on. Check connections thoroughly, and fuses in other devices, like head unit.
Aug 30, 2014 | Polk Audio polkaudio SWA500 Power...
My screen is not working
Make sure that you have everything plugged in correctly and that everything is receiving power. Double check connections that you already think are secure.
Mar 02, 2011 | Computers & Internet
Replaced my Antec True 380S power supply with an Antec SL450 power supply (Antec box with Intel D875PBZ motherboard). I reconnected the new power connectors to the peripherals (correctly, I believe) and...
Thoughts: There are two connections from the power supply to the motherboard. One has 24 pins and the other has 4. Make sure they both are correctly (and fully) inserted.
Try powering the computer on with all the devices disconnected (hard drive, CD, etc).
var fctb_tool=null; function FCTB_Init_15e8cfb4d7a84105bf2a8d1b62aaa04e(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_1c3c34bdb69a4e1f8440979fca0d4587(t) { fctb_tool=t; start(fctb_tool); }
Jan 29, 2011 | Computers & Internet
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
I moved my home office desk a few days ago. I properly powered down my computer and unplugged everything. When I reconnected everything, the computer won't power up.
1 - Make sure you have power to the outlet you plugged the computer into. 2 - Make sure all of the cables plugged into the back of the computer are firmly seated / attached.
3 - Check that the switch on the back of the computer (usually quite near the power cord) is turned on.
Jan 06, 2010 | Dell Computers & Internet
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
No power on connects to computer fine
First I would make sure the batteries are fresh, installed correctly, and the contacts are clean of corrosion. If everything is correct and clean then unfortunately your RCA mp3 player is no longer any good. I also had the same issue with an RCA a few years ago. Best of luck!
Source: Owner of Woodland Park Computers www.woodlandparkcomputers.com
May 14, 2009 | RCA RD1076 MP3 Player
Nothing turns on
Make sure the positive and negative power leads are hooked up correctly, and the correct usb interface is used.
Sep 29, 2006 | Pioneer DEH-P4800MP CD Player
MSI NF750-G55 AM3 NVIDIA nForce 750a SLI HDMI ATX AMD Motherboard Logo
70 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
