Question about Indesit W 123 Front Load Washer
Indesit. where is the filter on this machine
My indesit 123 auto wont spin or empty any suggestions please i need to do washing,
Posted on Jun 04, 2008
    Brigadier General:
  • 6,966 Answers
Most Indesit washing machines have hidden filters and are not meant to be customer accessible. If you are referring to the incoming water supply, then in some models, it would be immediately after the connector; if on the other hand, you are referring to the lint/fluff collector/filer, then there is no real filter but rather is a part of the drain system. Normally it is at the very bottom of the machine. You need to remove the lower front panel. There would be 3 clips that holds it in place. Once the inside is exposed, there would be a black circular cover at the right hand side. Unscrew it out and clean the inside. It would normally be filled with water and some other "stuff" so pls have cleaning materials handy and/or anything to absorb the spilling water.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 24, 2008
  • Louie  Role
    Louie Role May 26, 2008
    Glad to be of assistance and appreciate the rating.
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Is there a filter on a indesit wdg1095w
The lint filters on washing machines over the past 10+ years are mounted unter the tub. When the spin cycle starts, the water drains out of the tub, through the filter to clean it out/off, and out through the drain hose.
Apr 30, 2012 | Indesit Washing Machines
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
Indesit WG1234T - is there a filter and spin cycle not effective
If there is no filter located at the bottom right front of washer behind a re- moveable cover, then you need to remove the rear cover of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should help solve your prob.
Jan 05, 2010 | Indesit W 123 Front Load Washer
HI MY INDESIT 1063W WILL NOT SPIN PUMP KEEPS ON GOING DOOR LOCK NEW NO FILTER ON FRONT OF MACHINE
There should be a removable plastic panel at the bottom front of the m/c.
I f there is and you remove it, you should see the filter there.
Dec 03, 2008 | Indesit Washing Machines
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Apr 18, 2008 | Washing Machines
Indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Jul 17, 2007 | Indesit W 123 Front Load Washer
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
339 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
