Question about MSI MS-1036 Barebone
Power problem needing repair
I have a 1998 compaq presario. A few years ago my brother-in-law soddered a new connection for the power supply onto the laptop. Shortly thereafter it broke out. Are there any other ways to get power to the computer other than a new battery?
Msi mw 2006 3 cd of mico has
Posted on Jun 03, 2008
How do I replace the power supply, and can I use one from an SR1738NX?
Before attempting to replace the power supply, I would check to see if they are compatible. I would check to see that the wattage of the Compaq Presario SR1738NX is the same or larger than what is in your current computer. This information should be on the label of each power supply.
Next, I would check the connectors to ensure that all the connectors that are currently connected exist on the old power supply.
Next, take pictures of all the power supply connections on your new machine.
Finally, remove the power supply from your new computer, replace it with the power supply of your old computer, reconnect all of the connectors, and turn on the machine.
Good luck,
Paul
Dec 21, 2015 | HP Compaq Presario SR1910NX (EX310AA) PC...
I need a power supply model atx250w-12z
part number you need is KJ383AA, KJ383AAR
they have the dimensions that fit your computer please look for your self. Measure your power supply you have.
New PC Power Supply Upgrade for Compaq Presario SR5450F KJ383AA Computer
May 14, 2014 | HP Compaq Presario SR5450F Desktop PC
Need the schematic for the power supply for compaq presario sr1630nx
You do not ever attempt to repair a power supply. Between the high energy capacitors and the excessive voltage and amperage, there are no usable parts. You would have to buy the exact same model. Since this computer is about 5 to ten years old, you should be wise and do like the professionals do and get a new power supply. For Christ's sake, they are only 15 to 45 US. Be safe, do not electricute yourself for that price.
Feb 08, 2011 | HP Compaq Presario SR1630NX PC Desktop
My compaq presario 2100 will not start up the power cord plugs in and when you wiggle it it somtimes would work but now wont at all. thank
1. You possibly have a damage ac cord
or you have damaged connecting plug at the PC .
2. try to obtain a new AC cord.
3. Another possibility is the power supply for the PC needs replacement.
4. A PC technician can determine this for you.
Contact Compaq for repair rates because most likely this is a special power supplied system.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
Compaq presario power supply
You probably need a new power supply. Check the capacitors inside the power supply, they're probably popped. If they're not popped, bring it to a computer repair shop and have them test it. Your board could be bad, too.
Jul 03, 2009 | Compaq Computers & Internet
Motherboard failure
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). A failed video card will also give you "No signal message", but the computer should sound normal when starting up. Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
Mar 11, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
No display at all
gcmichaud:
Take out the RAM and turn on the computer. It should freak out. If not, your motherboard has gone. The good news: your data is safe. If it does beep like crazy, turn the computer off, remove the battery AND ac, reinstall the RAM and hold the power button down continuously for a good, slow count of thirty. Plug in the AC and try again. Let me know if you have any other questions/problems. I'll monitor this thread.
jslo:
It sounds like your power supply died. It's a pretty common problem. Can you get a friend to lend you their power supply? If so, hook it up and see if everything works. My bet is yes.
Jan 28, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario M2000 DEAD
My power plug that goes in the computer gets hot enough to melt the plastic ring on the end of the plug. so i am going to get a new power board and try that.
Jul 27, 2008 | Compaq Presario M2000 Notebook
Presario 2200 Notebook won't power up
try disconnect power then remove battery,plug power back in and try to boot.if nothing happens put battery back in and see if it charges.if it does leave to charge for a while,try to boot if it dont boot you know its neither the power or battery and shouldnt cost too much to repair(probably a capacitor dead , possibly transistor blown diodes only allow electricity to travel in one dirrection so only break if shock(drop or bang hard) resisters have about a 100yr life.
Feb 22, 2008 | HP Compaq Presario 2200 Notebook
MSI MS-1036 Barebone Logo
77 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
