Question about Car Audio & Video
How do you remove a Hyundai 2000 Excel car radio and replace?
SOURCE: I just changed battery and
try the last 4 digits of your VIN followed by 1212
Posted on Aug 28, 2008
dj_ricko_198
  • 128 Answers
SOURCE: radio code for 1997 Hyundai Excel
if you have the owners log books for the car look to see if the code is in there
if you do not have it then you need to get the model and chassis number from the top of the unit
then you need to go to Hyundai and they will get the code number and they will give it to you
i think you are better off going and getting a new cd player and having that installed
hope that helps
ricko
Posted on Dec 27, 2008
  • 45 Answers
SOURCE: car radio code
Call the techinal support number on top the radio they should tell you it. Hope this helps, good ratings help me out. Have a nice day
Posted on Jan 13, 2009
  • 4 Answers
SOURCE: remove hyundai excel 97 dash
Try this link and best of luck.
file:///D:/Car%20maintinance/Index%20of%20_hyundai_manual.htm
Posted on Jun 11, 2010
SOURCE: Hyundai Excel brake lights stay
Mine does the same and I am currently getting it fixed.
Basically the brake pedal, when not depressed, is placed against a switch which turns off the brake light (even when the car is not on). There is a rubber disc that connects the two, which in my car has disintegrated into bits. If I stuff things between the two (like the crumbling bits of the rubber disc) the brake lights turn off, but as soon as I use the brakes again, the bit I stuffed in falls out. You can look at it yourself, but it is in a difficult spot around the top of the brake pedal.
At this stage I am been advised that I must replace the whole switch, but I am contemplating finding an improvised solution (like tap washers) as it seems a simple problem to fix.
Posted on Nov 30, 2010
I have a 94 Hyundai Excel. I am replacing the clutch but can't find the torque settings anywhere.
clutch/flywheel torque settings - Hyundai Forums : Hyundai Forum
www.hyundai-forums.com/...accent/146383-clutch-flywheel-torque-setti...
Aug 2, 2012 - 3 posts - ‎2 authors
Im after the torque setting for the clutch and fly wheel for a lc 2000 accent with the dohc 16v engine. cheers.Missing: .94
Torque value head bolts 1994 hyundai excel 1.5l - Fixya
www.fixya.com/cars/t12339610-torque_value_head_bolts_1994_hyundai
Apr 7, 2012 - SOURCE: torque settings for a hyundai accent 1500 1998. cylinder ...SOURCE: how d i change a clutch in a hyundai excel 1994. Hi first lift the ...
Flywheel & Pressure Plate Torque Specifications? - Hyundai ...
www.hyundaiaftermarket.org > ... > Engine, Intake, Exhaust
Dec 19, 2015 | Hyundai Cars & Trucks
How do i remove radio from 2000 hyundai sonata gls
there should be on both sides of the radio top and bottom hexagon holes get the right tool and then remove the radio
Sep 28, 2012 | 2000 Hyundai Sonata
Are struts on the front or back of this car?
The struts model (MacPherson Strut),are both in front and back of this car.
2000 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Rear, Driver Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly. $72
2000 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Rear, Passenger Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $68
1996 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Front, Driver Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $67
1996 - 2006 Hyundai Elantra Shock Absorber and Strut Assembly - Front, Passenger Side, KYB GR-2/EXCEL-G, Twin tube, Strut Assembly $63
Of course this is only the cartridge, you have to transfer the spring, and the top mount of the existing strut. You need a pair of coil spring compressor to do the job. The basic procedure to replace a strut is:
Remove the top nuts that secure the strut assembly to the frame mount inside the engine compartment. Do not remove the center nut.
Mark the lower strut mounting location on the hub for installation reference. The alignment will be close if the new strut is installed in the same position.
Remove the bolts that hold the strut assembly to the hub.
Remove the strut assembly from the vehicle.
Mark the top mount for installation reference. Using a side mounted spring compressor, compress the spring and remove the top nut and retaining washer. Pull strut assembly out from the bottom of spring.
Slide the new strut assembly up into the spring and reposition the top mount onto the spring in the same position that it was removed. Install the retaining washer and top nut.
Tighten the top nut to the manufacturer's specifications and carefully remove the spring compressor.
Place the strut assembly back into the vehicle.
Oct 16, 2010 | 2000 Hyundai Elantra
Taking out the stock radio in my 96 hyundai excel
You must first remove the faceplate bezel surrounding the radio.
You need to gently pry the cover off the fake switch on either top side.
Then remove the ashtray to access the two bottom screws.
once removed there should be the screws visible for the radio mount.
Sep 14, 2009 | 1994 Hyundai Excel
I need a radio code for a 94 Hyundai Excel GS
You have to call the dealership with your vin,then they will give you the code.
Jun 23, 2009 | 2000 Hyundai Elantra
Radio code for 1997 Hyundai Excel. Factory supplied radio.
hope that helps
ricko
Dec 01, 2008 | 1994 Hyundai Excel
Radio code for 1997 excel
CONTACT HYUNDAI OR YOUR LOCAL DEALER THEY CAN SUPPLY THE CODE WITH PROPER OWNER INFO.RICHARDM69
I just changed battery and then i found i couldn't use radio anymore. The window show "code" everytime i tried to turn on radio. My car is 1995 Hyundai excel.
You need to re-insert radio code . If your radio is factory provided you may ask code from local hyundai dealer.
Give radio model number to search if can be found also on web.
Aug 06, 2008 | 1994 Hyundai Excel
Car Audio & Video Logo
62 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
