Question about RCA R52WM24 52" HDTV Projection Television
My 52" rca tv will turn on but then after a litle while it shuts off what could be the problem
  • 130 Answers
Hi
first you need to check when you turn on tv if the picture is to abnormaly wide this would indicate
a faulty power suply witch triggers the shut down
Posted on Sep 28, 2010
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
Turns on stays on for about 5-10 min then shuts off will turn back on in about 2 min 52" rca projection
For starters..you have two bad electrolytic capacitors. If you change them now you may be able to save this TV from a bigger problem. Like a new flyback and a retrace cap. If you can..look inside the back cover and look for two bulging caps. I'm telling you what I've heard other TV techs discuss.
Dec 23, 2009 | RCA D52W23 52" HDTV CRT TV
I have an RCA 52" screen TV and I was watching tv and all of a sudden the picture went blank and then the TV shut off. When I try to turn the tv on all i get is a scratching noise and then it turn off. can...
Hello again you need to Rate my solution other wise they are not going to pay me! since i did give you correct answer to fixing your TV ThanK You Replace 3 capacitors cp150 2200uf use 25v and cp114 cp120 220uf 35v.
Dec 19, 2009 | RCA HD52W58 52" TV
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca tv
when it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Jun 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
