Question about Boston Acoustics BA735 Computer Speakers
Hello, i unplugged the speakers to move them and plugged them back in and there not working now?
I unplugged my it188b speaker from my pc yesterday. When I plugged it back in, it wouldn't play, the pc speakers play instead. How do I turn off the pc speakers and get my sound bar to play again?
Check your computer set up. It might have switched the speakers off when you unplugged it. If that doesn't work it could be the jack plug itself. But often you can tell it's faulty due to if it's moved it might come back on again.
Sep 09, 2017 | The Computers & Internet
Receiver worked last night. I turned it on this morning and it just clicks over and over. Never comes on. I have to unplug it just to make it stop clicking.
What is the model number of this receiver? It could be in Protection Mode. Is power button on the unit flashing red? If so, that's protection mode. It could be as simple as a speaker wire got crossed or cut but it could also be something internal.
Step 1: Label all wires plugged into the receiver so you know where to put them back.
Step 2: Unplug everything, including the power cable.
Step 3: Leave it unplugged for 10 minutes.
Step 4: Plug in *just the power cable*
Does it still click? If so, it's an internal component that's bad.
Does the clicking stop? If so, add one wire at a time, waiting 1 minute before plugging in another wire. Keep adding wires till the clicking comes back. Once the clicking comes back, unplug the last wire you plugged in. That wire has a problem. It could be the wire itself or the device connected to the wire. If it's a speaker wire, for example, it could be that the wire got chewed or cut, or it could be that the speaker got fried inside.
Mar 19, 2016 | Denon Audio Players & Recorders
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
I have a DC Z-92 amplifier,PD-Z82M CD player,PLZ-92 Phono deckand F-Z92l tuner, was working fine till moved house,lost manual on how to connect it back up again,can hear very faint sound from speakers but...
first make sure you have phonograph and everything else plugged in where it belongs. or better yet unplug everything and start over. plug in just one source or just use the tuner. make sure that the speaker wires are not shorting out on the back of the amp or at the speakers. if there is a speaker switch on the front (for speaker A or Speaker B) make sure speaker A is pressed in (if you hooked up Speaker A on the back (you may not necessarily have speaker switchs.) make sure when you try the tuner that it is tuned to a good solid station. If after all of the above it still doesn't work, maybe the move caused somthing to come loose inside
Mar 20, 2011 | Pioneer Audio Players & Recorders
Hello please help. These speakers were working just fine and they right over a year old. For some reason I get no sound at all anymore, and when I unplug and plug it back into the computer it detects new...
turn the power on, then unplug it to computer and touch the input, if there is no crackling sound the amplifier is defective, a technician guy like me can fix the problem
Jun 19, 2010 | Dell A215 Computer Speakers
Since moving house can't get sound from PC speakers, packed, unpacked, disconnected and reconnected myself, I must have missed out a connection or connected something wrongly. Regards Stan
I suppose that you have plugged the green plug of the speakers in the green socket from the mainboard, in the back. And , of course, the speakers are still functional - try them with any other device that has a 3.5 mm plug.
Probably the audio setup was disturbed: unplug the speakers from the pc, reboot, plug in the speakers - the Audio Manager (the one that controls what and where is plugged) should open to ask you what has been plugged. If it doesn't do that unplug the speakers again and open it manually. If when you plug the speakers it doesn't sense that then the audio driver is busted - reinstall it.
Nov 09, 2009 | Acer Aspireā„¢ T180 PC Desktop
My computer speakers just went silent in the middle of a song
Do the speakers have power? Check the fuse.
Where are you plugging your headphones?
Where are the speakers connected? Is it the same jack as the headphones?
Have you tried plugging the speakers into the headphone jack vs the soundcard?
Mar 13, 2009 | Harman Kardon HK695 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
No sound
I had this problem as well. I would get sound from headphones but unplugging them I had no sound from the builtin speaker.
When you plug in your headphones it moves a thin piece of metal in the jack which interrupts a connection (this is a good thing) so it can know when to disable the internal speaker. When you unplug your headphones the piece of metal moves back and it enables the internal speaker again.
I was able to fix this by taking apart my x51v and bending the piece of metal a little while the headphones are plugged in so that it will contact better when the headphones are unplugged,
To take your axim apart there are 4 screws on the back underneath the rubber grips that you need to take out. Then you can just slide a finger nail up and down each side to remove the front and back of the casing. The back you will need to swing out from the bottom since it hooks over the headphone jack. I unplugged the small wire that connects the front half of the case to the guts using a tiny flat screwdriver.
Inside on the back, there is a black plastic plate that is held on by 4 more screws. Take that off.
Now you can see the headphone jack. I plugged in my headphones and used a small flat screwdriver to push against the headphone jack on the bottom piece of metal on the right side with the axim face down. You can observe the piece I mean by looking at the side of the headphone jack when you plug and unplug headphones. It moves perhaps 1/32 of an inch.
Your goal is to bend the piece of metal closer to where it is when no headphones are plugged in. The only way to bend it properly is to do it when the headphones are in.
Sorry if this isn't clear enough. I'm not sure if this is a permanent fix or not but it's worked for me.
Jan 04, 2009 | Dell Axim X51v Pocket PC
I can not a diagram
usually the green connector is for speakers
Sep 04, 2008 | Computers & Internet
Boston Acoustics BA735 Computer Speakers Logo
27 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
