Question about Broderbund 3D Home Architect Deluxe 6 (383204) for PC
How do I get the dimensions of the windows and doors to print out on the blueprints?
  • b_cook Sep 28, 2010
    How do you display them on the blueprint then? There isn't a box to click under windows or doors and there is nothing on the view filter or dimension toolbars either. Obviously if they appear on the blueprint they will be printed out - but the issue is getting them to appear on the screen to start with. Thanks.
    President:
  • 2,777 Answers
Do they display on the drawing before you print it? There should be an option to print with dimensions... but they have to be visible on the drawing before it's printed. Does the preview / what you're looking at include the dimensions?
Thanks
Tim
Posted on Sep 28, 2010
  • 2,973 Answers
There is a way to display the measurements on the blue print. Whenthey are displayed then they will appear in the printout as well.
Dimensions for whirlpool GU1200XTLS2
DOOR AND PANEL PARTS Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/gu1200xtls2/1198/.../00001.html
DOOR AND PANEL PARTS diagram for model # GU1200XTLS2 Whirlpool-Parts Dishwasher-Parts (24). Full Size. Print ... Owners manual Part #: 8283509.
Whirlpool Dishwasher Model GU1200XTLS2 Parts from ..
Jan 03, 2016 | Whirlpool Dishwashers
Window and door rough out Openings
Usually adding 3/4" to 1" to the actual window or door size (for a prehung door) works well. Blueprints can vary, some are the actual window and door opening ,some are rough openings. Usually rough opens will be followed by R.O. Hope this helps.
Dec 26, 2013 | Microsoft Windows XP Professional With...
Can I build my own aquarium stand?
Building your own aquarium stand is a great DIYproject! It can be easily (and cheaply)done with materials bought at your local hardware store. Here is a great website in which you plug inthe dimensions of your tank. The sitethen offers you different stand blueprints based on your specifications. Good luck!http://www.fishandtips.com/index.php
May 13, 2012 | Fish
Are there Window 7 drivers for the Gesetner A045 wide format plotter available. If not will there be?
Go to this web site http://www.ricoh-support.com/ and see if there is what you want.
The equivalent model is Aficio 240W.
Go to the quick search and in the left tab scroll to the wide format an in the right tab select the model (240W).
See you!
May 11, 2011 | Gestetner A045 Wide Format Copier
Having a problem with the power window drivers side Took the door panel off All the cables and pulleys are disconnected Never seen a power window system like this before Need to look at a blow up drawing...
Theres no need for that blueprint trust me, the window regulator is no good, what happens is a cable pops or a plastic wheel for cable breaks and they cant be repaired, the regulator comes complete you ust install, heres a picture of it.johnjohn2_61.jpg
Feb 18, 2011 | 2000 Chevrolet Impala
What is engine blueprinting?what is needed to bring out more power to the engine? For example, could mere balancing of like let's a pulley add some power to the engine? Thanks.
Blueprinting is a very exhaustive and extensive process of rebuilding the engine. When the engine is designed, there are specifications for every dimension of every engine part. Since the parts are mass-produced, there is no way that they can be made exactly to spec, so there's a tolerance allowed on the parts (for example, the weight of a piston would be specified as X number of ounces, plus or minus 10%). Same for connecting rods, wrist pins, the inside diameter of each runner in the manifolds, weights and dimensions of valves, etc.
When an engine shop blueprints an engine, it means they build it to the exact specification for each part and clearance in the engine. They may order 50 pistons for a V6 engine, and will measure all of them for all size and weight dimensions, and won't stop until they get six that match exactly. They'll then do the same for the six rods, six wristpins, the valves, crankshaft, etc. They'll take the intake manifold and will usually bore it out (or extrude-hone it, which involves flowing a high-temperature, abrasive clay through it at high speed/pressure to polish and enlarge the volume for better airflow). Ditto that for the exhaust manifolds. They'll do a full hot-tank treatment on the block, metallax the block (alternate heating and cooling of the block to make the crystalline structure of the engine block metal more regular, and thus stronger), cross-hatch the cylinders for oil retention on the walls (better lubrication and less friction as the pistons move), order cams with an optimum grind for valve lift and duration (this determines the airflow characteristics of the engine, where it'll make peak power and torque, etc), they'll knife-edge, balance, micropolish, and shotpeen the crank for less turbulence in the oil pan and lighter rotating weight (so it doesn't drain as much power), and they'll assemble it all to exacting fit and torque specs.
The end result is that you can gain 20% or more output from the engine, or even more still if they do porting/polishing on the components, extrude-honing, etc. With that stuff and custom-spec cams, the output could go up 30-40% even. It's a big power gain, but it comes at a big cost (as I'm sure you can tell). It's only really worth it on a race engine. Anyone who says they can blueprint a motor for a grand or less is full of it. You'd honestly be looking at $2000 or more easily if you only rebuilt it to stock spec with stock parts. Using aftermarket, high-performance parts, custom cams, extrude-honing, porting and polishing, etc, can easily kick the price up to $5000 at the least, and depending on the components you buy, $10-20,000 is very easy to ring up. It's not for the faint of heart. But it may be all the difference in racing, especially in an SCCA class like Spec-Miata racing, where engines have to be unmodified (as in, using only OEM parts). There's no rule against blueprinting as long as the parts are all available at the dealership parts counter. It says you have to use stock parts, but it doesn't forbid you from using the best possible combination of stock parts possible.
Nov 17, 2009 | 2004 Pontiac GTO
Everything I print is so small I can hardly read it.
when you go to print the window that pops up before it comes out will allow you to change the print size and the number of pages it goes on try that one
Apr 05, 2009 | Dell Dimension 1100 PC Desktop
Punch Pro Platinum CAD program For some reason, the 3-D view of the front wall of my house suddenly "disappeared" while I was 'navigsting around the premises! !!! It only shows as a thick...
How much memory does your video card support?
Chances are it isn't enough for 3D animation. You might want to go with a 256mb video memory card.
Aug 11, 2008 | Punch ! Super Home Suite (695985)
Broderbund 3D Home Architect Deluxe 6 (383204) for PC Logo
50 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
