My internet screen does not show the full page and the scroll bars do not extent to the full page picture. How can I adjust this?
    President:
  • 1,768 Answers
1. place mouse cursor on the blue header an use the right click. On the drop down menu select "maximize"
2. If this doesn't work then you will have to reset the browser to "default " settings.
Posted on Sep 28, 2010
My box on my computer will not go down far enough for me to get my answers? What can I do to go further down?
Change the pixels on the images to a lower setting if thats possible, or change the font size.
Oct 25, 2017 | Cars & Trucks
How to record from netflix to chromebook c7
netflix streams are DRM protected so don't get your hopes up ripping the video with a simple piece of software.
Jan 27, 2014 | Acer C7 Chromebook
My screen of computer is so big the contents are enlarged my kid has pressed some buttons pls help
Hi nayyarshelly,
I like to help you regarding your concern having big Icons on your desktop, you mentioned that your kid accidentally pressed something on the machine that made everything big, See steps below to changes the Icons or your systems desktop settings.
  • First the system should be turned ON and logged in to Windows, I am assuming that you have Windows7 on your computer.
  • On the keyboard Hold down the CTRL button while holding down the CTRL key on the mouse scroll, scroll backwards this should make things smaller again.
  • If the screen on the Internet is also big do the same thing while your Internet Explorer is open this should change the size of the text / pictures anything on the Internet explorer.
  • But if the above does a different function from what you are experiencing then I believe that you are experiencing some changes in the resolution of the screen if everything is Enlarged.
  • Click on Start then on the search bar type in display, a list will show look for Display then click on it to open up the Display window then click on Adjust resolution.
  • The resolution on your screen depends on how big the LCD screen is
  • On the Resolution page you can pretty much check each resolution on the list that will be better to you, then click on Apply lower right then OK to apply settings on this page.
I hope that this will be of help regarding your concern.
Have a nice day,
mvincentc
Apr 24, 2011 | Computers & Internet
The page on-screen look thin and I want to make it wider image on screen. I need large text and page. How do I adjust the screen image?
You can make it by adjusting screen resolution. Right click on an empty space on desktop and go to properties, there click on Settings Tab. There you can see Screen resolution options. Drag the bar to adjust your display as you like. Once done click apply and OK
Mar 29, 2011 | Computers & Internet
I have a wide screen Acer monitor, yet am unable to view my whole web site without scrolling down. I have adjusted the resolution to allow the font to fit on the page, and can see it perfectly with IE,...
Sounds like either your display resolution needs to be set higher or when you bring up firefox after the page loads press and hold the ALT key and Click View, ToolBars and select Menu Bar. This will keep it at the top everytime you open firefox. Now under View you can zoom in and zoom out. You can also select Full Screen. *** Before doing anything did you click the middle box at the top right hand corner of the screen between the - and red x? This toggles between full screen also.
Feb 25, 2018 | Acer X243W 24" TFT wide format screen 24...
Full screen
Press the F11 button to get full screen.
To return back to normal screen, press the F11 button again.
You can also hold down the CTRL key on the keyboard and Scroll down the scrolling button on the mouse.
To revert to normal , again hold the CTRL button on the keyboard and scroll upwards.
Cheer
Uttam
Jul 12, 2010 | Advent Netbook
Cannot see full width of page on screen
if you are referring to online pages, for internet explorer browsers you must click 'Page', scroll down to 'Zoom' and choose 100% to fit everything on the screen. you may also want to adjust text size or screen resolution. hope this helps. please rate me and thanks for choosing enterprise computing solutions
Sep 30, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Web pages were full page; now they're oversized
Try Going to "View" on the "Command Bar" and go to "Zoom" and check it for 100%. If you don't see "Command Bar" right click on any empty space on your toolbar and select "Command Bar". (File, Edit, View, etc.). Ian.
Jul 30, 2009 | Computers & Internet
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Facebook not showing full screen; reported tech probs on page
For all problems dealing with facebook I suggest you talk to a human being directly.
Facebook customer service 650-853-1300 Palo Alto, CA 156 University Ave., Suite 300, Palo Alto, CA 94301.
ttt
Oct 09, 2008 | Facebook Social Network
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
