Question about Canon PIXMA MX310 All-In-One Printer
My Mx310 is receiving faxes in memory and I cannot print the faxes that are stored in memory
  • Canon Master
  • 3,530 Answers
Make sure first that toner is not low on ink, paper is out or there is no paper jam.
I am providing you a link on how to print the faxes stored in the memory. Jump to page 58.
If you are doing the steps above and you are still unable to print, please feel free to come back.
Posted on Sep 28, 2010
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
I want to print a fax but it says 'received in memory' how can I print it? Thanks
To print documents received in memory
1. Press the fax button, then press the menu button.
2. Press the button to slect MEMORY REFERENCE.
3. Press ok button twice.
The memory lists is printed
When confirming printing or deleteing a document stored in memory, you specify it by its transaction number (TX/RX NO>) transaction mode, recipient, number of pages date and transmission number. If you do not know the transcaction number for your target document, print the lists of docs first.
Nov 20, 2010 | Canon PIXMA MX310 All-In-One Printer
My printer is telling meI have a FAX "received in memory". How do I get it to print?
First of all, don't unplug the machine. Your user manual has a section called Printing a Fax from memory. CanonUSA's web site has the documentation if you've lost your manual. Basically, it involves going to the Fax memory, and print a transaction stored in memory.
There''s an online user guide that you can download under Guides and Manuals, here http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Carl
Jan 29, 2010 | Canon PIXMA MX310 All-In-One Printer
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Paper has run out
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
Hope this helps!
-- RT
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One - faxes storing instead of printing
When the machine is in one of the following situations, the fax is automatically stored in memory.
- If ink is low or has run out while receiving a fax
- If the paper size/type setting is incorrect
- If the paper has run out while receiving a fax
- If the Output Tray is closed
- If OFF is selected for AUTO PRINT RX
- If you pressed the Stop/Reset button to cancel printing of a fax
The most likely problem is that the ink is low.
You can change the settings to still print if the ink is low by pushing the fax button and then the menu button.
Scroll over until you get to RX settings (I think it is the 6th option) and push OK.
Choose the option to Auto Print RX, and press OK.
Make sure that On is selected and even if it already is the chosen option, press OK.
When the option appears to print with no ink, select yes. This will allow the fax to print even when the ink is low.
Sep 04, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 Printer - Faxes being stored isntead of printing.
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
184 people viewed this question
old marine
old marine
