Question about Samsung HL-R6167W 61" HDTV
We have a tv that after 1 yr has started to have white spots. Started with a couple then has spread vigorously. What could this be? Thank you...Elizabeth
  • Samsung Master
  • 5,138 Answers
You need to replace the Light Engine .
Encompass Parts Distribution 1-800-638-3328
UED 1-800-648-6657
Posted on Sep 28, 2010
Why does my led screen have a white spot
may be the panel, in which case it should be under warranty. This unit has a 1 yr mfr warranty , if less than 1 yr old it would be covered. contact servicer for service immediately before warranty expires
Sep 09, 2014 | TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
White spots on sony bravia 32" S series
what is the cause for the televisions screen to get white spots that spread
Aug 05, 2013 | Sony BRAVIA Televison & Video
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
BAD LIGHT ENGINE call UED 1-800-648-6657
Feb 15, 2009 | Samsung HL-S4266W 42" HDTV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Lamp
Sounds like the ballast and lamp need replaced
Mar 10, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung HL-R6167W 61" HDTV Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
