Question about Bryant 462AJC021BA Air Conditioner
We have a 6 year old air conditioner Byrant 591B. The outside unit is not working it make a slight hum when the thermostat is set to cool, but the fan does not run. The furnace is working fine
    Habit-Forming:
  • 156 Answers
You picked the wrong picture...lol. You have a split system and that humm you hear comes from the contactor. That means the thermostat is asking the compressor which is outside to come on. If you hear the humm but nothing is working, Check the breaker and then replace the fuses in your fuse box by the condensing unit, or the outside unit if the breakers are OK. It should have a disconnect between 3 to 10 feet of the unit depending on your codes and city requirements. No matter what, if you stand at your unit and look at the conduit, it will lead to your electrical disconnect. It could be a sub-breaker or fuses. It is usually fuses because a breaker could take up to 6 sin waves to respond as where a fuse could take only 2 sin waves. Replace both fuses. As time goes on, fuses become warn from constant load changes and heat and sooner a latter, they just wear out like any other component. Change the fuses and fire your unit back up. If it pops the new breakers, you have other issues and it's time to call an HVAC guys.
Posted on Sep 28, 2010
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
We have a Goodman Furnace and Air Conditioner approx 7 years old. When I put the Cool on thermostat and lowered the temperature for the air conditioner to come on the furnace fan started but the outside...
You are right. The outside unit starts quickly. The humming will either be the evaporator fan or the AC compressor itself. If you can reach into the evaporater fan with something narrow and stiff you may be able to see if the fan turns. Sorry for the trouble you are having.
One or the other is trying but unable to start, hence the humming.
Wayne
Jun 11, 2010 | Heating & Cooling
The outside unit of a whole house air conditioner
replace start run capacitor of motor fan
Aug 17, 2009 | Heating & Cooling
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
A/C Stopped Working
outside fuses are blown on condensor unit at dissconect
Jul 13, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
No cold air-the compressor unit outside does not come on.
I believe the soft hum you are hearing is the contactor pulling in. You can check by standing by the outdoor unit and have someone inside turn the a/c on and off at the thermostat. If the contactor is being energized you will hear a distinctive click as it energizes or de-energizes. If this happens check your main power sources to the condenser. Make sure the circuit breaker in the fuse box is turned on. Also check your outside disconnect box that connects to the condenser. Remember this is high voltage so be careful. A lot of these disconnect boxes have cartridge fuses inside of it. You will need a voltmeter to check the continuity of the fuses to make sure they are ok. Just one being bad could make the condenser inoperative. If you need to change the cartridge fuses, make sure you put in the exact size needed. putting in the wrong size for you unit can cause problems. Always buy "time delay" fuses . They cost more but they will not blow out on initial start up like the cheap ones will. I hope this info helps you....
Good luck...
May 01, 2009 | Weather King 10AJA6001AH Air Conditioner
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
Bryant 462AJC021BA Air Conditioner Logo
169 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
