Question about Cell Phones
Where is the sim card in an lg290cm phone - Cell Phones
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
How do I hard reset my lg290cm?
Before you do master reset. Try to switch off your phone and remove the battery. Leave it for an hour or more then you can switch it on back again. It this doesn`t work the you will have to do a master reset. There are several ways to do this using physical keys. Below are some ways to do it. Hold Volume + and power for 20 seconds Hold Volume - and power for 20 seconds Hold Volume + and power for 20 seconds Hold volume + and home and power for 20 seconds Hold reset button for 30 seconds. Hold Volume - and home and power for 20 seconds. these will all do a hard reset. you can also locate a tiny hole around your phones cover pressing it for 20 seconds. Let us know if it works!
Jul 29, 2014 | Net10 LG290C Pre-Paid Cell Phone
My lg290cm phone got wet and now all it does is flash the LG logo on and off until you remome the battery. Is there any way to reset the phone to factory defaults?
Take everything out and put it in a bowl of rice to dry out for 24 hours. If the indicators (small white stickers under and on the batter) aren't white, your phone might be toast. Good luck!
Jun 15, 2011 | Motorola Mobility TracFone w175 PayAsYouGo...
I have an lg290cm phone that has a cracked screen and wont come on at all
Then you need a new phone.
hopefully your contacts are synced to your SIM Card
best of luck
Feb 27, 2011 | LG Lotus Cell Phone
I can't send pictures from my lg290cm.
sir your handset wont support picture message
Jan 08, 2011 | LG Cell Phones
LG290CM TRACFONE MANUAL
como desbloquear lg290cm trackphone
Sep 13, 2010 | Cell Phones
Lost pictures on broken phone
hello,
the answer to your phone problem NO !
it so because the body is no more compatible
what you have to do to solve this phone problem (i.e to retrieve your picture )
is to make sure that the phone problem is fix before you retrieve the picture from the panel
thank you and thanks for using fixya.
Jun 25, 2010 | Cell Phones
Want to down load pictures off my LG290CM
I tried what tinchur did but it didnt recognize my phone even when I selected othe cdma phone.
Jan 25, 2010 | Cell Phones
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
103 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
