Question about True T-49 Side by Side Refrigerator Commercial
My refrigerator temp keeps going up and down - True T-49 Side by Side Refrigerator Commercial
  • True Master
  • 17,129 Answers
Check if the thermostat is working , will need to see that the thermocouple react to a simulated temperature. Also check if the compressor is running constantly without a break. If not check the relay of the motor.
Posted on Sep 28, 2010
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
Temp
move temp sensor into coil area if not helping replace sensor
Sep 21, 2012 | Dometic RM2620 Refrigerator
Samsung refrigerator alarm keeps going off
the alarm goes off when the temp in the fridge is to warm it is not tacking the temp down to the setting thats sellected could be the stat fauty
Dec 02, 2011 | Samsung Refrigerators
My GE Profile side by side refrigerator keeps going to express thaw mode and temp is way out of range. Any ideas on the problem?
Nov 24, 2010 | GE Profile PSS26NGS Side by Side...
Refrigerator wont cool
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Feb 01, 2010 | Refrigerators
Keeps running and freezing eveything, replace temp switch still freezing up
No the temp wire should be not on top of the coil but running down the middle all the way down to the bottom of the cooler. Try this first and if it doesnt work let me know
Jun 02, 2009 | True TD-65-24 Commercial Refrigerator
Samsung r521jlmr
The sensor on that unit is probably near the door. This happens a lot on Walk in coolers/freezers also. As long as the temp goes back down in a few minutes, the unit is ok.
Jan 29, 2008 | Samsung RM255LASH Side by Side...
Explorer Gas Refrigerator
I have a 12 cubic foot explorer and have found that if the burner is not keep clean the effiency will go down. I also found that adjusting the flame to the lowest temp does not keep the fridge the coldest. Adjust the flame until you get an even blue flame with minimal yellow in it.You make the adjustment with the temp control.Also clean the chimney, I use a gun cleaning kit. Thanks Dennis
Jul 14, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
True T-49 Side by Side Refrigerator Commercial Logo
287 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
