Question about Sentry Fireproof Safe
Cannot open my safe, battery appears dead - Sentry Fireproof Safe
  • 17,130 Answers
Seems that you might need to get help from the security people as the battery needs to be replaced..there could be a method for the Sentry safe.
Posted on Sep 28, 2010
  • rwestcott250 Oct 27, 2010
    have a sentry safe A3821 5 years old works occassionally sentry says solenoid is bad but they no longer make. safe is now trash after only 5 years
  • Hannah Johnson Jun 24, 2011
    Hi there
    do you know which model it is that you have? The battery could be below the keypad or behind it depending on the model. It might be on the back of the door but that is only on two ranges of safes. If you need any further help it's worth contacting customer service.
My batteries are dead and can't find the keys so how do I open my safe
If you can't find the key you may need a lock smith
Oct 28, 2014 | Home Security
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Dec 07, 2010 | Sentry Fireproof Safe
Dead battery! CANNOT OPEN SAFE
This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
May 09, 2010 | Safe International Digital Electronic Safe...
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
Jan 11, 2009 | Sentry Fireproof Safe
Batteries are dead can't open safe
I had the same problem. We finally located where the batteries were hidden. They were below the keypad, There is a silver, plastic cover that slides to the right to expose the 4 AA batteries. Hope this helps you.
May 11, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
593 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
