When my Samsung SW60ASP is set to spin only it spins for a few minutes then automatically changes to rinse.
  • Washing Mach... Master
  • 17,129 Answers
Might have to check your program control module for erros as it shuts off the rpogram without completion.,choose anotehr program to check, if not the internal timer/driver has a fault.
Posted on Sep 28, 2010
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
Whirlpool washer duet sport ht MOD # WFW8300SW02
did you try to diconnect it from wall?
try to disconnect it.... wait for 5 minutes and try to connect it again and try if same problem still occurs....
Jan 13, 2014 | Washing Machines
What should i do? It continues to add time and cycles?
just press the botton of each cycle want u want,like add rinse press rinse botton and it will add rinse,press spin botton it will add spin,but for washing,cant coz already set the time,default program for wash and cannot change
Oct 31, 2013 | Samsung WA50F9A8DSP Platinum 5.0 cu. ft....
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
