Question about Roper RAX4233PQ Top Load Washer
My washer will work on everything except the spin cylcle...it will not drain the water out. Please help....don't know what to do
  • 347 Answers
Replace the defective lid switch,it is under the control console. their are screws in the back of each end cap securing the control panel to the top. Also make sure the screws holding the left side hinge to the lid are tight because they also move the arm that activates the lid switch. very easy repair Good Luck
Posted on Sep 28, 2010
Washer not draining but motor still hums
I would get to the water outlet pipe and blow hard down it to try and clear any blockage if not take the pump housing apart to clear the blockage eric
Dec 24, 2017 | Kenmore HE2 Plus Front Load Washer
I have a kennmore elite front loader washer and have taken off the front bottom cover and cleaned out the drain (a pen, some coins and a clear ball) I took the hose off completely by loosening the coil...
try unplugging it and lkeave it unplugged for at least hour that should reset it ,sud of course refers to low water flow into pump but i am sure that has been resolved
Jul 20, 2011 | Kenmore Elite 45986 Front Load Washer
My washer is 2 years old everything works except when it gets to the spin cycle then it wont spin and it doesnt drain the water ,any suggestions? please help. percy.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 20, 2011 | Maytag PAV2300 Top Load Washer
My washer dont drain water and don spin but aggigates.please help
your washer house is to low it has to be sink level or 90 dgree angle for it to drain after drain it sould go in faze mode to spin if not your belt is bad.
Feb 06, 2011 | Westinghouse WWS833ES Super Capacity Top...
The washer is saying F20 code...It drains the water once I press cancel...I just relocated it, now no longer will spin and drain water...Please help...have check hoses, water taps, everything and it drains...
Check to be sure that the drain hose curves up higher than the washer tub. If that does not help, check to sure the unit is level...next turn the washer off, unplug the washer for a few minutes , then replug it into the wall outlet.Be sure that you are standing in a dry area and that your hands are dry. This may reset the operating system. If it has water in in after this, try the drain and spin cycle, and then try a regular quick cycle to see if it works.
Good luck to you, and if this does not work, get back to us.If your problem is solved please let us know by rating this answer. Thank you for using FixYa.
Dec 28, 2010 | Kenmore Elite 45986 Front Load Washer
How do I fix my Kenmore washer spin cylcle? It
if your machine is a top load , less than 15 yrs. You most likely need a new lid switch. The machine will not drain or spin if the top lid is open.
Dec 12, 2009 | Washing Machines
1 year old kenmore washing machine won't spin, agitator works OK and the water drains, just won't spin.
you have a bad door switch everything on a washer works fine with a bad door switch except the spin cycle
Jun 07, 2009 | Washing Machines
Bosch washer wont drain
you do not need a repairman! Buy the correct part from appliancepartspros.com-they are very helpful (I checked the part number on the BOSCH website first). The aprt cost me $48 and some cents. I (being a professional woman, = not a repairwoman!) changed the unit in less than 45 minutes. See my other posts for the procedure.
Jun 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Admiral is not spinninng
i would say the simple soulation to this is get the main belt tightened.sounds loose???.hope this helps.adrian
Jan 31, 2009 | Admiral AW22 Top Load Washer
Spin cycle doesn't work
The lid switch is broken.....
Oct 19, 2007 | Kenmore 22422 Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
