BIOS does not have the option of Disabling graphics card
I have the windows XP SP1 and I generally apply SP2 after installing XP. In my BIOS there is no option of disabling the PCI graphics card. The system has NVIDIA GeForce 8400M GS graphics card. Please let me know how to disable it.
  • 3,422 Answers
Please check each and every option in the BIOS because that the only way to disable it.
Also go through the microsoft link which i gave you.
Posted on May 24, 2008
Disable intergerated video card to allow for pci card to function
You need to access the BIOS to disable the on-board video. Do you have Windows 7 installed or have you upgraded to Windows 8?
For Windows 7, turn off the computer and then turn it back on. After pressing your on switch press Delete repeatedly to access the BIOS. (Some computers use Tab or another key, you should see a screen indicating the correct key.) If Windows starts to load, try again. (I usually have to try 3-4 times to press the key at the correct time following the POST.)
For Windows 8, the boot sequence can be too fast to hit the key. Use the Advanced Restart option. Access the Charms menu and choose Settings > General > Advanced Startup. Alternatively, Charms > Settings > Power > press Shift and then select Restart. This should give you a Boot options menu and you'll be able to access the BIOS from that.
On my machine, I need the Advanced BIOS and then the System Agent Configuration. Then I select Initiate Graphics Adapter. Your BIOS may be slightly different. Go through your VGA graphics for disabling the on-board graphics and enabling the correct PCI/PCI-e graphics option.
I hope this helps.
(make sure that your power supply will support the graphics card.)
Mar 17, 2013 | eMachines ET1331G07w (884483025329) PC...
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
Intel or AMD Dual Core processor, 1.6 GHz or greater
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
When i uses window xp sp2 then 3d games runs faster then when i uses window 7
Windows 7 uses a lot more of your computer's graphics capabilities than Windows XP does. Try turning off Aero in Windows 7 and disabling unnecessary options like animation or cursor shadows to free up some graphics memory and processing.
Jun 05, 2010 | GrandTec GVC-1000 (gvc1000) VGA Video...
Installed xp hot fix, then aardvark would not work, so I uninstalled hot fix. Now when I install cd for software, I get aarkthk.dll not found. Please help
All aardvark interfaces will only work well with xp sp1 or earlier 2000/win98. Also, dont simply uninstall SP2, 3. You have to unistall/reinstall xp, xpsp1 and then if needed, go to the microsoft download pages and get all the updates prior to SP2. Pay attention and make sure you dont install SP2. Do all of this with the pci card pulled and all aardvark drivers uninstalled/deleted. Then install per aardvark's instructions. I dont recommend internet usage without SP2. You will be vulnerable to attacks even with the best protection.
Feb 04, 2010 | Aardvark Direct Pro Q10 (bundle) External...
How i can install xp sp2?
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from .com
May 09, 2009 | Computers & Internet
How to uninstall Vista and load XP in Lenovo Y510 Ideapad
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP;en-us;316941
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
May 23, 2008 | Computers & Internet
C2881 wont boot after sp2 installed
Generally when an SP2 installation doesn't take it means that there was some corruption of the SP1 installation. Usually virus related.
Although it is possible, I doubt very highly that replacing hardware will fix this problem. This is a software related issue and should be repaired as such.
You'll need to boot to the XP recovery console and then perform an uninstallation of SP2. Then you'll need to disinfect the SP1 installation (check for winlogon infections!)
Please, do not attempt to physically replace the BIOS ROM. You'll probably brick your motherboard.
If this doesn't solve your errors or you need more information please post back with what BSoD you're getting when the computer starts. And if possible upload the .dmp file from C:\Windows\Minidump to a file hosting service.
Apr 29, 2008 | E-Machines eMachines Desktop PC
Can't Get To Advanced Options
XP updating to SP1 seems a little odd in february of 2008, why not SP2?
To get into your BIOS you need to hold down escape key as you turn your laptop on and keep it held down until it reports an error, then press F1 to check BIOS. You can actually alter BIOS from within the OS environment with Toshiba laptops through a utility called HWSetup and I suspect that's where your problem lies.
Make sure your audio device is enabled in BIOS and if you need to re-install HWSetup you can find it here:
Hope this helps,
Feb 15, 2008 | Edirol UA-4FX External Sound System
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
