Question about Brother Office Equipment & Supplies
Brother AX 24 Daisy Pinwheel. Lock it in start typing goes okay for a while and then starts typing letters different than what is typed. Any clue as to what to try to correct problem?
  • Brother Master
  • 3,594 Answers
Remove the printwheel, rotate it manually look for bent or broken spokes, if they are allright try using the T/W without a correction tape. If this works you may have a tacky L/O which catches the P/W.
DickyO
Posted on Sep 28, 2010
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
The keys typed are not the letters coming up
The SX 4000 is a "Daisy Wheel" printer. A plastic Wheel with the letters embossed on them spin via the input of the keyboard. I would suggest that your Daisy Wheel mhas slipped its index, presenting a offset letter., or the wheel is on inproper, but I do not see how it could happen, short of forcing it on. You may have to buy another Daisy Wheel, if that one is broken at the hub. See:
http://www.google.com/products/catalog?rlz=1T4SUNA_enUS250US259&q=daisy+wheels+for+brother+typewriters&um=1&ie=UTF-8&cid=5918209752341457784&ei=aqEHTeebDs6s8AaP-9nnAg&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CDEQ8wIwAw#
Dec 14, 2010 | Brother SX-4000 Typewriter
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
I'm trying to type on this, but it's not typing the letters I am touching. It types a different letter than I press.
turn machine off for 15 or so seconds and turn back on. if that doesn't work, remove the daisy wheel and inspect the spokes the letters are on. look for bent or broken spokes.
Oct 29, 2009 | Brother SX-4000 Typewriter
I type a letter and a different letter comes out (i.e. i type the letter M and the letter R comes out)
change your daisy cassette wheel, this part is consumable. it is already wornout
Sep 10, 2009 | Brother GX-6750 Typewriter
BROTHER ELECTRONIC AX-22 RANDOM LETTERS
Check to see if there is a switch on the left side of keyboard for international or symbol printwheel selection.
Jun 17, 2009 | Office Equipment & Supplies
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
