Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Install Hard Disk
Hi!
I would like to install hard disk on my compaq presario 2500 laptop. I cannot open the machine though. Please advice.
Thanks,
Cecilia
    Problem Solver:
  • 11 Answers
Should be located right under the TouchPad.
Turn off your laptop, unplug and remove the battery, remove 3 screws (one is covered by a rubber grommet) and you should be able to slide it out no problem.
There are two screws which attach the HDD to the plastic piece. And there are 4 screws which attach the cage to the HDD. You will need to remove these both and attach them to your new HDD.
Installation is reverse of removal. Good luck :)
Posted on Feb 26, 2009
There are 3 screws, look just under the opening catch, you will see 2 screws, the other is behind the little rubber grommet, remove all three drive then just pulls out!
Posted on May 28, 2008
    Genius:
  • 3,587 Answers
No need..its under the bottom of the computer, and you can there are two screws holding it or four..be careful not to lose them
Posted on May 27, 2008
Compaq Presario v4000- how to do a factory reset?
umm without a drive this is just a netbook install a drive and then you can proceed compaq's don't work well without an operating system which is on the hard drive
or is the disk drive the cd drive reader that you are referring to
May 29, 2012 | Compaq Presario V4000 Notebook
What button do i hit at start up to reformat the hard drive on a compaq presario 700
Hi purple7558
did you mean format the hard disk and then install the operating system.?
press F10 to enter the bios setup, then set the boot sequence to cd rom first.
insert your windows cd into the cd rom.
save settings and restart. after the computer restarts it will detect that you enter cd then press enter.
the next process is the usual kind of format and install your operating system.
thanks&regards
Jan 10, 2011 | Compaq Presario 700 470024-192 Notebook
I have a Compaq Presario V3309TU Notebook PC. I reformatted the hard drive, now I could not install windows XP cd. The hard drive could not be detected. Can someone help me get the SATA Driver for Compaq...
The problem is that XP installation CD does not have a SATA driver, unless you have a Compaq SATA drive on a disk etc and can install it when XP asks for a hard drive driver, then XP cannot detect the hard disk and therefore won't install XP.
The Fix.
Go into the BIOS and disable the SATA drive, this will make XP think it is a IDE/PATA hard disk. Then install XP normally, and all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 14, 2010 | HP Compaq Presario V3000T Notebook
I tried to install the XP in my laptop compaq c700 (vista basic ) getting the error " replace the hard disk"
Greetings my friend, please try to format first your hard disk before installing Windows XP to prevent error causing by the vista operating system setup settings.
Thanks
Jan 07, 2010 | Compaq Presario 700 470024-192 Notebook
Problem with compaq presario 2500
hi
go to the Bios setup and set the first booting device as CD drive and it will check the CD first
cheers
pls rate if it was any help
Jul 05, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Harddisk is not getting detected
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your
Apr 28, 2009 | HP Compaq Presario CQ60Z Notebook
Re-formatting the Hard Disk
It sound like you have a Sata hard drive that needs Drivers an order to access the drive, using a floppy and F6 at windows setup. send me more info on your laptop model and make.
Oct 23, 2008 | HP Compaq Presario V6000T Notebook
Compaq presario 2500 does not boot
you got an OS problem try to re install your OS.
Oct 17, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq Presario C734TU
Enter BIOS Menu and look for Hard Disk SATA IDE setting of AHCI. Disable this by setting to Compatible mode.
XP does not support AHCI mode.
Please rate me if this works.
Aug 05, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
