Question about Watches
The second hand is not moving
I have a Citizen 8700 BL8000 54L watch. I noticed that since last weekend the second hand of my watchis stuck and is not moving in normal mode. It seems that the hand itself can move (for example, when I am setting up time, the hand is reset to 6 o'clock position automatically). I hope this is not due to any serious problem. (I am sure I have not dropped the watch or bumpped it anywhere).
Any Help please?
Thanks,
SR MY SECOND HAND IS NOT MOVING SINCE THE DAY I BOUGHT IT
  • CYRUS86 May 24, 2008
    ya sure i realized that big second hand is used only for chronograph.
Make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
Posted on Nov 30, 2010
Are you sure the big second hand is not used for the chronograph? I once had a watch that did exactly that. There was a small second hand in the lower left which was the normal secondhand, while the big second hand was used only for the chronograph. It annoyed the cr*p out of me, so I always had the chronograph running, just so the second hand would move.
Posted on May 24, 2008
3 Suggested Answers
SOURCE: the second hand is not moving
I have the same problem with my watch. The second hand
tends to stop even if it's not dim. Leave the watch outside
in bright sun for several hours. I've found that this will charge the watch so that afterwards,
the second hand will work even inside (well, not all the time,
but if it's fairly bright).
Posted on Jul 03, 2008
jsantosh2008
Got the same problem guys.
but is there anyone from this website going to answer this problem.
lots of people are facing this issue, help us with the solution. This is not a technical problem.
I pressed the buttons in my Guess watch when it was new and the second hand stopped. I tried all options to turn it on, no go
Posted on Jan 03, 2014
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Can set time on watch eco drive
Here is a simple steps to set up the time:
Pull the crown out one notch
Turn the crown to align the mode hand at the time mode Time
Pull the crown out another notch
Turn the crown to set the 24 hour hand, hour hand and minute hand to the current time.
Return the crown to the normal position in synchronization with a telephone time signal or other time service.
For full instruction and visual about your watch kindly click on the link.
I hope this will help you resolve your issue.
thank you for choosing Fixya
Mar 05, 2011 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How do you know witch setting to make on the leap year adjustment on the Citizen Calibre 8700 model. +1, +2, +3...?
On Leap Years, the function dial is to be set to '0'.
Add one for each year after...
So, for 2011, set the function dial to '3' since it has been 3 years since 2008, the last leap year. Next year it should move/be set to '0' again since 2012 is a leap year.
Dec 23, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
Aug 01, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
I need to know how to set my 8700 calibre watch
Hi,here is a solution to help you out:
1. Pull the crown out one click.
A. Turn dial until function hand rests on "CAL"
2. Pull dial out one more click (should be all the way out)
A. hold down button "A" (top button) until the second hand completes one counter clockwise rotation (should be pointing at current month)
B. Press "A" button a second time and the Day/Leap year hand will move.
3. At this point spin the crown either backwards or forwards and watch as the Day/Leap year hand spins clockwise or counter-clockwise. The Date will adjust per each revolution.
However,you still have every reason to own the manual of your wrist watch for future references,so follow the link below to download the manual of your wrist watch;
http://www.citizenwatch.com/COA/English/settings.asp
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Thanks and take care
Jun 20, 2010 | Citizen 8700 BL8000-54L Wrist Watch
My Citizen Eco-Drive second hand is broken
I think Its required Recharging capacitor
Put your watch under lamp light for 12 hours I hope that will solve the issue if not then capacitor need to be replace or watch need cleaning
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Oct 01, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Aug 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Got the same problem guys. i have one of the new electronic diving eco drives.
First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
Jan 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Watches Logo
4,554 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
