Question about Dryers
My wife just finished drying a load of clothes in our Whirlpool 9250 dryer, cleaned the lint filter, and put in another load. When she went to set it to an automatic cycle the machine simply beeps three (3) times like when you attempt to change the temperature in an automatic cycle the time on the display flashes at that point until cancel is pushed. I tried switching to manual cycles with the same results. I also tried unplugging this for several minutes and plug it back in and nothing changes. Any thoughts?
  • Todd Didier Oct 16, 2010
    Okay, I purchased a new thermistor with the hopes that that would fix the problem. Once I got into it everything tested out okay according to the service diagram. There was a bunch of dirt
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 28, 2010
  • 1 more comment
  • Todd Didier Sep 28, 2010
    I'm guesing the three beeps mean something? The control panel appears to be working and lights up but when I attempt to start the cycle I get three beeps and the time on the display flashes. The dryer will not do anything. The motor does not hum. The belt seems intact when I trun the drum by hand it is turning the motor. The dryer is a Whirlpool Duet 9250 and only 4 years old.
    The door switch turns off and on the light inside the dryer fine. I assumbed it was working properly but could it still be bad?
  • D. Floyd Kolb
    D. Floyd Kolb Sep 28, 2010
    No,
    The door switch should be good then...it must be something more involved like the thermal fuse or the thermostat...
    At this point to troubleshoot it you almost need to use an electrical meter and start to flow the power and see where it stops at...then you know what the problem is...
    heatman101
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Have a whirlpool electric dryer. My wife said that she noticed a burning smell from the back of the dryer while it is running. The clothes are still being dried though. Any suggestions? We have had this...
Usually, lint has found it's way into the burner chamber. This is often evidenced by small brown spots on clothes. To resolve, unplug the machine and open it up and investigate the burner area.
When finished cleaning, remove the outlet hose, turn on the unit and form an opinion about air flow.....Hook hose back up, turn machine on, and go outside the building, and verify very similar air flow volume. Any restriction will slow drying and allow more lint to get drawn into the air inlet.....
Mar 21, 2011 | Whirlpool WED6400S Electric Dryer
I have a Whirlpool commercial dryer model number LEQ7030KQ1. I will wash a load a clothes in the wash machine and they will come out so they are as spun dry as they can get. The problem I experience is...
Did you mean that you need to press manually to have the drying done well, if so the program settings is what is wrong?
Does a good timing setting work on the set?
Please clarify more.the fault you are.experiencing.
Sep 28, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
I don't know how to use my whirlpool dryer
Add clothes, close door securely, make sure it latches, select a cycle (timed dry, permanent press, etc.) select a heat setting ( low heat, high heat, or air) a push the start button. You will also want to make sure the lint filter is cleaned between each load. The lint filter will be either on the top of the machine under a little door or inside the machine at the bottom of the front.
Nov 22, 2009 | Whirlpool Dryers
Clothes taking 2 hours to dry
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
For Sublime appliance repair advice, simply written:
http://sites.google.com/site/sublimeappliancerepair/Home
Apr 09, 2009 | Dryers
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
How do you get the dryer to actually work?
That button with the 1/2 on it and then the time dial works and it sounds as if it is washing your clothes, but it is actually drying the clothes but heats up water in order to do it. It is kind of insane actually but it does work and that is the way to do it.
Do you know if there is a place to clean a lint filter? Is there a lint filter somewhere?
Sep 21, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
