Question about Sony Handycam DCR-TRV22 Mini DV Digital Camcorder
Supported USB drivers on Windows Vista
I have a Sony Handycam DCR-TRV22 mini... I need a USB drivers which can be supported on my windows vista for recording the stuff from handycam to my PC.. I am hving s/w but it does support on my windows vista
  • 2 more comments
  • Anonymous May 26, 2008
    I encountered the same problem. My old computer with Windows XP was hit by power surge and I goa Vista PC as its replacement. Vista does not recognize Sony DCR-TRV22 and I cannot find driver from Sony support page.
    Victor Chao
  • Anonymous Jul 02, 2008
    nothing
  • widget767 Oct 02, 2008
    Help. Vista won't recognize the DCR TRV 22.
    What to do! Sony site is no help...
  • Anonymous Apr 07, 2009
    Same here. No compatible USB driver in Vista. Even tried using original ImageMixer install disk. No dice.
There is no driver available for this model. Sony sucks !!!
Posted on Sep 29, 2008
After plugging in my DCR TRV350 (Sony Camera) with Vista and using it for quite a while for video editing, I am discovering that Windows all of a sudden does not recognize it and is needing the USB drivers which of course refuses to install them. It worked fine with XP and initally with Vista, but after formatting my vista computer, it just doesn't work anymore. Someone please help!
Posted on Oct 20, 2008
I need a dcr-hc85 driver for windows Vista where can i get it
  • Windows Vista Starter edition is not supported.
  • The USB streaming feature is not supported with 64-bit Windows Vista operating systems.
  • The drivers required to connect most Sony┬« cameras and camcorders to a computer are already included in the Microsoft Windows Vista operating system.
    Note:
    In some instances, the camera or camcorder may not be recognized by the computer when connected. In this case, check to see if there is an updated driver available for your model.
    If the above link doesn't work, you can check to see if there is an updated driver at this address:
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC85
    Hope this has helped you.
    www.austintelstarservices.com
    Sep 03, 2010 | Sony Handycam DCR-HC85 Mini DV Digital...
    Cant instal drivers
    usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
    May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
    I have windows vista and i cant install the usb driver and pixela programs for this handycam please help me.
    the usb driver and pixela application is not compatible with windows vista. usb streaming is not supported by windows vista and 7 OS. however it would still be possible to transfer videos from your dv camcorder using the dv interface (ieee1394 or ilink) connection. you would need to have an ilink (ieee1394) card installed in your computer. you can check by going to device manager window. if you don't, try checking with your PC manufacturer recommendations for an ieee1394 chipset or card.if you do, all you need is an ilink cable (btw, the cam uses 4pin jack).get the correct cable for use with the PC and camcorder, and use windows moviemaker for your video capturing software.hope this helps.thanks :)
    also, here's the support site for your unit:
    http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=odw_en_GB&m=DCR-PC101E
    Mar 31, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
    Is it possible to use a SonyDCR-HC32 handy cam
    To use fire wire connection and Windows Movie Maker is the simple way to import video and make movies.
    Aug 29, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
    USB connection with Windows Vista
    Install Win XP pro or Win 7 on your computer.
    Vista sucks!
    Aug 14, 2009 | Sony Handycam DCR-PC350 Mini DV Digital...
    Hi. i hv a dcr-trv22, i hv lost the software CD. whr can i get the software or what is the eastiest method to solve it. plz help me fast...
    Windows XP & Vista should automatically recognize the camera (hardware) when you plug in the USB cable. You don't need the Sony software.
    Oct 30, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
    Compatibility problems with Vista
    Download driver update for Windows Vista from Sony Support for DCR-TRV22 camcorder.
    Sep 06, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
    Need drivers for Sony Handycam DCR-TRV22 using windows vista
    HI! THERE USE TO BE AN ADAPTER FOR THOSE MINI'S TO USE IN A VHS, BUT I HAVEN'T SEEN ONE OF THOSE FOR AGES! GAD, IT'S HARD TO FIND A VHS THESE DAYS! WITH ALL THE DVDS AND BLURAY STUFF. BUT, DID FIND THIS SITE FOR YOU.
    GOOGLE THE FOLLOWING: SONY E SUPPORT DCR-TRV22-SOFTWAREUPDATES&DRIVERS.
    THEY CLAIM TO HAVE THE DRIVERS AND SOFTWARE TO HOOK YOUR CAMERA UP TO YOUR COMPUTER! LOTS OF LUCK! IF YOU NEED MORE HELP, REPLY TO:
    ARCLIGHT1217
    Mar 31, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
    Open Questions:
    See all Sony Handycam DCR-TRV22 Mini DV Digital Camcorder Questions
    Sony Handycam DCR-TRV22 Mini DV Digital Camcorder Logo
    2,136 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
