Whirlpool WFS1273AW Front loader The clean pump light is on, how do I clean the pump?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Remove bottom panel. You should see a trap on the pump. Rotate cover ccw. Have pan ready to catch some water, or some towels.
Posted on Sep 28, 2010
  • 1 more comment
  • blossomclean Jul 19, 2011
    i did this and its still showing the clean pump light????? what do i do now?
  • Amy Walters Apr 06, 2012
    thanks for the tip, but you have to make sure up pull the tap out to collect what is in side. I got a bonus $4.35 out of it.
    worked a treat, but you have to make sure you pull the pump out and collect what is inside. I got a bonus $4.35 out of it
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
How do I clean the pump on a front loader Whirlpool washing machine, when the filter is spotless. (Red Pump clean light is on) Machine doesn't drain properly leaving clothes soaked.
If you have a top front small panel, unscrew 3 or 4 screw then you can pop out the cover. The pump is right there, you can counter clockwise the filter out and clean the pump. Be aware to do it with the power off.
If you don't see the front small panel, you have to open the back cover at the back of the unit.
Oct 13, 2013 | Whirlpool Washing Machines
Whirlpool front loader WFS1273AW why is thewater continuing to run during cycle
If it's only on one cycle it is a controller fault giving the inlet solenoid power all the time. This would be very unusual. It is more likely to be something in the inlet valve allowing water through.
Apr 21, 2012 | Washing Machines
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
My Whirlpool washing machine WFS1273AW, has been displaying "clean pump" and F02. I have cleaned the pump and even had a repair man change the pump. However the machine won't move beyond the wash cycle and...
The same thing happened to me and it was because there were socks stuck where the drain pipe attaches to the machine. If you tip your machine on its side and pull the black pipe off from the bottom of the drum you can remove anything which is stuck. Then it just clips back on again with a metal clip.
Aug 31, 2010 | Washing Machines
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a wfs1273aw and its "clean pump" light is on an will not finish wash what do i do?
It sounds like your "drain pump" is either blocked or seized. Does the washing machine have a coin trap or small door at the front? If so, then open it, unscrew the plunger behind the door, then check inside for any foreign objects/material. Tip: Using a torch helps a lot.
Jun 16, 2009 | Whirlpool GHW9150 Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing machine
cloged hoses or pump
kinked drain hose
May 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
984 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
