Question about Logitech Z-5500 Computer Speakers
No digital input
My z-5500 doesnt pick up any digital signal is it a circuit problem ?
  • 167 Answers
The digital input is for conection to dvd player or any other device that has digital output. so if you connect any other type of output it will not work. i have same speakers for couple of years, and know them inside and out (awesome speaks) i hope this is useful info,good-luck.
Posted on Aug 02, 2008
Cant stop tv from scaning
your tv might be an analog kind of tv and doesnt pick up digital signal since its an analog, secure a digital converter and set ur tv to channel 3 so u can pick up a digital signal and tv will stop scanning.
Nov 25, 2014 | Televison & Video
Bridge adcom gfa-5500
not unless it has a Bridge switch OR you design an inverter circuit for one of the inputs. If it has XLR inputs you can try to invert pins 2 & 3 on one of them, that might work...
Aug 12, 2012 | Adcom GFA-5500 2-Channel Amplifier
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 cam position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor
or electronic spark control circuit fault
44 oxygen sensor lean exhaust
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
Problem
There are no more analog signals, the fcc has forced a change to digital,
remember the big thing for a year about getting a tuner, well if your in the USA.
Make sure that in the settings menu you are set for digital, read your manual
on how you can tell which signal is being picked up.
Feb 07, 2010 | Vizio VO42L 42 in. LCD TV
No picture/signal
what u need to do is check your antenna as well as check that your tv is getting input on the av/hdmi/etc inputs, if your tv is still not picking up antenna signal, try on another tv unit or try the tv on anothe antenna signal. If you get no tv signal u need to replace the tuner printer circuit board, the one with the rf tuner module on it. Good luck.
Nov 15, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I can't seem to hook up my Insignia T.V. and my dvd player up
The way to hook up the dvd player to the television to to put a cable into the output signal section of the dvd player( Ther may be many different ways to hook-up the signal s-video and component video, regular video. You must pick one of these output signal sources to put into the input section of your television by matching them up i.e s-video out to s-video input compnent video output to component video input, regular video out to regular video input. For each of these video hook-ups there will also be a set of two sound cables. Look on the back of your television for the signal input section and hook up the video cables and the sound cables to your selected input. You should do this with both units turned off in order not to damage the circuits by shorting them on cable insertions ofr causing heavy feedback in the circuits. One this connection is complete. Trun on the television first and select the TV's signal source . By pressing the input button and using the up and down arrows to find the correct selection. By matching up all three sources you now should have the correct signal path. Turn your DVD and test the controls. try using the volume control and use you dvd to to play,ff, or stop the dvd.If all this works then you have done the set up correctly and can now enjoy your dvd's on the television Hope this helps you with your problem..
Mar 23, 2009 | Insignia 37" LCD Flat-Panel HDTV
My jvc 1080p shows no input selection for "tv" . It only 3 video inputs and no tv input anymore. There used to be more items shown when I hit the INPUT button, including the choice for tv. But...
did you remove the rear panel of the set while the cord was still plugged in? Doesnt have to be on, if the rear cover is removced even for a second while the cord is plugged in you have destroyed the digital circuits and they will need to be replaced with the entire array of signal boards. JVC HDTV have that feature built into them so the average person cant do repairs without disableling that feature.
Jun 15, 2008 | JVC Televison & Video
Logitech Z-5500 Computer Speakers Logo
125 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
