Question about Bissell Vacuums
My vacume is less than 6 months old. I've gone through & replaced 4 belts. Now I realize the roller is not rolling which is causing the belts to break. The roller is free of all hair and debree. What should I do to fit the roller?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Very strong chance the end caps, made out of rubber could be a manufacturer defect. Many parts on vacs are made by different sources.
Posted on Sep 28, 2010
Why doesn't the brush roller rotate?
Hi, this is Jim with Crucial Vacuum,
The belt may not be broken, but it may be lacking in tension and therefore unable to rotate the brush roll on its own. You're going to want to replace your vacuums belt every 3 to 6 months depending on usage. Check to see if the belt is loose, or over stretched.
Check the brush roll as well and be sure its securely locked into place. It could be slightly loose causing a lack of communication between itself and the belt. Our video can help with fitting the belt in properly with the brush roll:
https://www.youtube.com/watch?v=LRV8280PQxc
You can purchase replacement belts and brush rolls for your Hoover Linx directly from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-linx-platinum-roller-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 05, 2015 | Hoover Platinum LiNX Cordless Stick Vacuum
Why wont brushes rotate
Hi, it's Allie from Crucial Vacuum!
There are several things that may affect the performance of your unit and cause this to happen. The roller brush may stop working properly because of the belts, the roller brush or the filters in your unit.
Belt are recommended to be changed every 3 months, not replacing the belts can cause them to stretch out and the roller brush won't work properly. If the belts are in optimal conditions and do not need to be replaced, this may have been caused by your unit's rollerbrush.
Roller brushes can be cleaned and maintained to avoid frequent replacement. Make sure that there are no hair strands or debris tangled up in the brush roll's bristles, this may cause the roller to not work. Monthly care of your brush roller will help to keep you vacuum working properly.
Last, make sure to check your filters, if the filters have not been washed (if washable) or have not been replaced, it can affect the suction and performance of your unit.
You can purchase direct your replacement belts, brush roll and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Alejandra (Allie) Sepulveda-Rivera
Aug 19, 2014 | Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
My Hoover makes louder noise when the brushroll is on. I just cleaned but no result.
What kind of Hoover is this? There are a few things that will cause excessive noise and vibration such as a worn belt, the wrong belt, damaged end caps, damaged brush roll housing and worn bearings. Inspect the brush roll area. Remove the belt, if you have a spare, check the size. If it's more than 6 months old, replace the belt. Spin the brush roll in the housing, does it spin free or hesitate or not turn at all? If it spins with effort there could be debris under the end caps; if one end cap will not turn there is enough debris to cause the end cap to internally melt to the roller. If you cannot turn the brush roll by hand, replacement is your best solution. You should also inspect the housing where the roller spins, specifically where the end caps sit; look for damage to the slots in the plastic, it the roller will not sit snug this could cause enough vibration to make the sound you're hearing.
Sep 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
Dyson DC4 Brush will not spin - have checked belt - this is ok
The bearings on your brush have gone bad. Buy a new roller brush and replace the belt as well, even if the old one seems o.k. Most people don't realize that roller brushes have bearings in the ends that allow them to turn quickly and smoothly. If you get hair wrapped around the roller brush, this will kill the bearings.
Sep 09, 2009 | Vacuums
Changing belt on Kirby Classic 1972
When you turned the knob, did it turn easily or hard. If it was easy, then the knob part inside did not catch the belt. If it did turn hard, when you had the brush roll off, did you check the ends to see if they turned easily or not. if not, then replace the brush roll.
Apr 15, 2008 | Vacuums
Vacuums Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
