Question about Kenmore Refrigerators
Kenmore model 363.9752714 Not cold enough in frig or freezer; food spoiling and rotting in days
Krazytech
  • 725 Answers
SOURCE: sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Posted on Oct 12, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
  • 400 Answers
SOURCE: Freezer not cold enough, frig ok Frigidaire FRS6LR5EM7
Your defrost element is probably faulty, this is in the freezer compartment at the back and behind a removeable panel. You should change both the element and the defrost limiting thermodisc at the same time.
Posted on Mar 05, 2009
kvhappliance
  • 218 Answers
SOURCE: Freezer not cold enough, refrigerator not cold
This could be the defrost timer or the defrost heater coil... The evaporator coils are located at the back of the freezer compartment. To access you will need to remove all the racks and then there is a cover held on by a few screws at the back of freezer and under it you will see the coils... Do not beat bang or scrape them... Use a hair dryer or heat gun to melt ice or you could just use hot water . Put your model #.JCB2388GTB into searspartsdirect.com and they will show parts diagrams.
If I can help with anything else please let me know.
Posted on Apr 13, 2010
  • 13 Answers
SOURCE: I have a Jenn-Air side by side frig. The freezer
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Posted on Jun 03, 2010
NEW KENMORE NOT GETTING COLD ENOUGH
Is there enough room behind the unit to allow it to ventilate properly? Most freezers and fridges need a minimum of 6 inches between them and the rear wall to allow for the extracted heat to dissipate. SInce it is only 3 days old, I would suspect that there may be a defect if the rear clearance is not the problem. Have you contacted Kenmore's Help Line? It is 1-888-KENMORE (1-888-536-6673) Give them a call and see if they can help/
Feb 13, 2012 | Kenmore Refrigerators
Hi my side by side wards refrigerator and freezer doesnt always get cold enough some times it will make ice and keep milk cold and other times wont make anything cold. it spoils milk one day and next day...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
We have a roper frig that we use for vaccine storage, the freezer does not stay cold enought for their storage; if we adjust to freezer temp for vaccines then refrigerator is too cold for storage
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Mar 15, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Each side won't get cold. food starts to spoil
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold, refrigerator not cooling enough to prevent food from spoiling within 2 days.
Most likely your freezer fan is out. Most of them are located behind the plastic trim panel at the back of the freezer compartment.
Jul 09, 2009 | Refrigerators
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
I have a 10 year old side by side refrigerator. Model No. ED20TKXDN01., Ser. SG0437491. The freezer portion works fine, plenty of cold air. The refrigerator portion is not staying cold, food is spoiling....
take back panel off inside freezer and check if there is ice build up. if so, melt off with a hair dryer and see if it works then. get back to me if you want
Aug 21, 2008 | Whirlpool Refrigerators
Food gets spoiled too soon
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Apr 30, 2008 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Refrigerators Logo
80 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
