Question about Refrigerators
I?m working A GE profile Refrigerator, Model # PSS26pssass. The problem is that the fresh food side evap keeps freezing over. I have changed out the main board and the fan cover assembly in the fresh food side. Now the is saying he see frost buildup again. Wow, I need help
  • 1 more comment
  • Michael Motley Sep 28, 2010
    No frost build up on the freezer side, Hmm? All the fans seems to working okay
    Yes, I'm a repairmen, but this one have me stumped. The compressor seems to work fine. I doubt if it's a bad board.
  • Michael Motley Oct 04, 2010
    Custmer called mr again today, it's totaolly frosted over. It's a GE profile Refrigerator, Model # PSS26pssass. The problem is that the fresh food side evap keeps freezing over. I have changed out the main board and the fan cover assembly in the fresh food side. Now the is saying he see frost buildup again. Wow, I need help
  • Refrigerators Master
  • 3,083 Answers
I know this is going to sound crazy, but a friend of mine swears he has the simple, inexpensive "fix" for this situation, and he claims it has worked on more than one refrigerator. He says that if you take a piece of copper wire (slightly thick), and wrap it around and connect both evaporator coils, it will help this situation.
Here's a suggestion for what it could be from homerepairforum.com:
Thanks Dan O. I spoke with a repair man and he suggested checking for heavy frost buildup in the back of the freezer compartment the next time this problem occurs. He said that the door ice dispenser outlet flap should also be checked as a source of warm moist air getting into the freezer compartment. Do you have any other suggestions that I should try to help determine the cause when the warming problem occurs again? FYI, I fortunately have an extra Fridge to store all the perishables while waiting for the problem to recur.
This web answer points to a possible bad defrost termination thermostat for GE units:
http://www.appliance411.com/links/jump.cgi?ID=659
This might dispel my friend's solution, since it could create other problems.
Here is a site with the diagrams, parts lists, and manuals for this model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5234117
Anyway, hope this helps you figure it out, and good luck.
Posted on Oct 04, 2010
    President:
  • 2,777 Answers
Wow indeed, that is a very strange one. There is no ice build up on the freezer side at all though? And all fans are working properly? Hmm, let me know and I will research it further for you.
Tim
Posted on Sep 28, 2010
  • Tim Grayson
    Tim Grayson Sep 28, 2010
    Strange indeed, so you sound like an appliance repair person then correct? Did you fully test the compressor unit itself and make sure it was fully operational? Otherwise I'd say it was the main board possibly malfunctioning on the temperature control, but you already covered that, unless somehow the new main-board is also bad, which I have seen in rare cases.
    Let me know,
    Tim
  • Tim Grayson
    Strange, still researching here to see what it could possibly be, without seeing it it's difficult to say. Discussing it with multiple people, will keep you apprised.
    Thanks
    Tim
My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Psc25mstass the evaporator is frosted up in the fresh food section. What keeps the evap. coils defrosted and or what makes them frost up? The fresh food section is not cooling>
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator PSS27SGNA BS....unit's refrigerated section keeps freezing food. even after we've adjusted the temp up to 36 or 37(recommended) it stays at 30 and keeps ruining the produce.
Check the air damper at the back top left of the fresh foods section to see if the damper door has broken and thus not able to close. It is electrically operated, but if it breaks, you can have your exact condition occuer.
Feb 03, 2010 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Can the fresh food drawers be disassembled?
yes they can be disassembled but it should not be special temperature drawer or zone which can be independetly controled otherwise you can change the temperature deviation in the compartment which can lead colder temp or below freezing .not good for the fresh food.
Jul 01, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
