Question about Thermador C301U Electric Single Oven
When i turn the oven on it says "off" how can i get it to turn on
  • 205 Answers
Hello- If you turn the oven off at the breaker, it should be a double 40 or 50 Amp breaker. And MAKE SURE both of the switches are off completely, there should be no display. Open the oven door and remove the black panel that is right under the control panel, where the top of the door would close on to. There are about 8 screws I believe. Once the panel is off you should see a thermostat right in the center of the cavity that you exposed about 4 inches back. It will have 2 wires coming out of it. The thermostat is about an inch in diameter and has a little red button in the center, facing up. If you can fit your hand in there press on the button and if it (the resettable thermostat) has been tripped it will make a little click. If you are concerned about having you had next to the wires even though the oven is off you can use a plastic pen to try to press the button down. Replace the cover plate and reset the breaker. If the thermostat got tripped the oven should work now. If it didn't and the oven still does not work then you may have a bigger and more expensive issue and may need a new relay board or possibly the EOC (oven control). Unfortunately these parts are very expensive and you will also need a Tech out to determine which one is faulty, there is some specific testing that has to be done on the boards themselves while the oven is live. I have seen this problem before and sometimes it is the relay board and sometimes the EOC. Hope this helps, best regards.
Posted on Sep 28, 2010
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Jun 03, 2015 | Moffat Ovens
Why is ignition still working after oven is lit
Oven Control Board
Relay board:
May 10, 2015 | Ovens
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 | Ovens
After cleaning the control panel ribbon, the oven will not shut down (top and bottom ovens. Is this the thermal oven shutdown fuse that needs to be replaced? If so, how do I remove the fuse from a W
Oven Control Board
Relay board:
Dec 28, 2014 | Whirlpool Ovens
Element heats up when we only put oven light on
Oven Control Board
Relay board:
Nov 17, 2014 | Whirlpool RMC305PV 30" Built-in Microwave...
Why will my whirlpool oven not cut off
Oven Control Board
Relay board:
Jul 28, 2014 | Whirlpool Ovens
Oven will not shut off just keeps getting hotter
Oven Control Board
Relay board:
May 21, 2014 | Whirlpool WOS51EC0AW 30" Single Electric...
DCS Double oven cooling fan will not turn off
Is this a convection oven? Need more info.
Mar 03, 2014 | DCS (WOTD-227) Double Oven
Whirlpool gold electric oven code pf and broiler won't turn off, oven goes into clean mode when baking
Oven Control Board
Relay board:
Dec 22, 2013 | Whirlpool RBS275PD Electric Single Oven
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Oven Control Board
Relay board:
Sep 12, 2009 | GE Ovens
Thermador C301U Electric Single Oven Logo
88 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
