Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
Bottom freezer not cooling Spoiled all perishables and ice maker thawed to water. Certain buzz noise originating from the refrigerator that seems to come and go
  • suweswbellne Sep 28, 2010
    Thank you for your reply, It appears a technician is in order. The model is approx 7 years old. Do you think pulling out the refrigerator and cleaning the coils would trouble shoot the problem? The lower unit is room temperature as of this writing. The upper section is maintaining. Tom
    Has there been a history regarding with this Amana model pertaining to my original problem described?
    President:
  • 2,777 Answers
It sounds like a compressor problem for sure. You may want to pull out the fridge and check the coils in the back and under the fridge. Look for ice buildup, does it appear to be built up on the coils? It could be just the compressor is going bad, but hard to say for sure. How old is this fridge?
Posted on Sep 28, 2010
  • Tim Grayson
    Tim Grayson Sep 28, 2010
    Not necessarily a history particularly with this model, they are pretty highly rated... You should definitely check the coils, but yes a service call is most likely going to be necessary regardless. If you want, shoot over your zip code and I will recommend someone in the area for you.
    Thanks
    Tim
Mbf2256heb maytag fridge My fridge seems to cool properly, but it is making this nearly constant buzzing or grunting sound that stops when you open the freezer (bottom) drawer. Suggestions?
Is you unit hooked up to water because if your unit has an ice maker and not hooked up to water currently, the ice maker will call for water about every 45 mins and cause this noise. To stop this action, lift the bail arm to the off position to avoid or stop this from occurring.
I hope this helps.
Oct 24, 2013 | Refrigerators
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
Our jenn-air side by side refrigerator with ice-maker has a problem. Quite often it makes a buzzing sound which seems to be more frequent than is normal. There is water inside the freezer which solidifies...
Good day,
You'll need to isolate the problem. Shut the water off to the machine to eliminate the ice maker as an issue. Clean up any mess left over and restart the machine with the ice maker set to the off position.
Run for a few days to test the quality of the cooling capacity of the machine. If it tests O.K. then the ice maker situation can be addressed.
May 10, 2010 | Refrigerators
Seems to be cooling fine but makes a buzzing sound for 7 seconds then stop.
The 7 second buzz would be from the water valve trying to fill the ice maker that is in the freezer.
My guess is that your refrigerator is not connected to a water supply. You can stop the buzz by opening the freezer drawer and turning off the ice maker, it will have either an on/off switch or an arm on the right side that lifts up and locks in place, that will stop the buzz
Apr 18, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
87 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
