Question about Altec Lansing inMotion iM310 Portable Speakers for iPod
The owner plugged the wrong voltage and/or polarity DC power supply into the unit and it smoked, and stopped working. She asked me to try to fix it. I finally figured out how to get the thing open without damaging the case (it definitely was NOT meant to be taken apart). I found several surface mount components burnt on the power input section of the circuit board. They are burned beyond recognition, and without the schematic or layout, I can't tell what i need to replace. If anyone has or knows where to get the layout and/or schematic for the AL iM310 please let me know
5 Suggested Answers
SOURCE: Wrong Power Supply
If it doesn't work with batteries or the supplied power supply than your speakers are fried. Sorry for the bad news.
Posted on Mar 03, 2009
SOURCE: Can't open/disassemble Altec Lansing im310
There is only four visible screws on the outside of the unit, which are the ones that everyone's found already.  Two are in the battery compartment, two in the storage compartment.  However I managed to find the location of the other TEN!  You need to take off the screens on top of the speaker.  The safe way I managed to do it was by using a very small flathead screwdriver and I would start at the bottom and work my way to the top on the outside edge of the speaker grill, just putting it between the grill and the plastic and turning the screwdriver up a little and inwards.
Once that's off you'll see four screws around the outside of each speaker and an additional screw sunk in above each speaker.  Once the screws are off, slowly just start to wiggle the two sides apart.  They're together tight, so just be patient and work it open slowly.
I should also mention that the ends of these speakers (that the seam doesn't seem to continue on) is actually a thin piece of plastic on each side and is stuck on with really sticky double-sided tape of some sort or rubber cement, something like that.  If you're careful, you can pull these off (slowly, once again).  It'll make pulling the two sides apart a LOT easier.
Hope this helps!
Posted on Apr 15, 2009
MrObvious
  • 115 Answers
SOURCE: My im310 smokes and smells, I get no sound. Repair
Replace, the cost of repairing something made in china is usually greater than buying a new one. I would just get a new one with fresh warranty.
Posted on Jun 22, 2009
SOURCE: Where can I get a replacement iPod connector circuit board?
The ipod connector on the board has the same footprint as the angled iPod connector made by JAE, part number DD1B030VA1. Someone moderately skilled in PCB rework should be able to replace it. The part is SMT with 0.5mm pitch pins, and it's right up against an epoxy blob, so it takes a bit of skill to solder by hand.
I called Altec Lansing myself and they will not sell a replacement part, so I am repairing my own.
Posted on Nov 18, 2010
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
Used my line6 adapter on boss mt2. there was a little smoke at the ac in. the pedal stopped working. please help!
Which Line 6 power supply? If you look at the specs stamped into the L6 supply you should see the voltage, current capacity, and polarity (if DC). Polarity would have a symbol showing an inner post and outer shell and indicate which is positive....referred to as positive or negative tip. Let me know what these specs are and I can have a better idea of what may have happened. Sounds like it burned out a protection circuit designed to protect the pedal from incorrect power applied. Will it still work with a battery?
Aug 25, 2012 | Boss Mt 2 Metal Zone Effects Pedal
Buying a used Tascam 788. P.O. lost the power supply. How can I get a replacement? Couldn't find anything on TASCAM site.
Hi, Provided there is a tag on the back showing the units model number, on that same tag should be the power requirements for it-buying a universal power supply, or even a used working one to another piece of equipment is acceptable as long as the polarity is the same. Polarity is located right next to where the power supply plugs into the unit. It will be a " circle with a dash inside it with a line connecting to a C looking symbol with a line coming out of it connecting another circle with a plus sign inside. " that is a typical outer ground/inner positive marking. a power supply will be marked the same. If they match the polarities are the same. Next make sure the power supply says the proper DC voltage and Milliamps or amps-Ma/A example: 2400Ma, 2.4a. I hope this helps and thank you for asking FixYa, good luck and don't forget to write back and let me know how I did, Prodzilla.
Apr 23, 2011 | Record Tools Tascam Dp02 8 Track Digital...
I have a rhodes 660, and it doesnt trun on. all u hear is a buzzing sound. does anyone know whats wrong.
This is LIKELY a power supply problem. The unit should have a label telling the power requirements. Match the polarity on DC units as well as the type AC od DC and voltage and current.
I suspect the input voltage from the supply is way lower than the required.
Apr 22, 2010 | Music
Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Mar 29, 2010 | Yamaha Music
I have Yamaha psr 260 and I am connect on 24V, and now speakers dont work. What am I doing?
I believe that is the wrong VOLTAGE !!!
The PSR takes a 12 volt, 1 amp or more DC power supply with positive on the pin.
If you have connected 24 volts either AC or DC of either polarity you have likely caused internal damage. Try a 12 volt DC supply and if it doesn't work, it needs to go to a repair facility.
ALWAYS check the voltage and the polarity on ANY of the devices using the power adapters BEFORE connecting the adapter..
Feb 18, 2010 | Yamaha Music
External power problem
It's actually the opposite. 1/8" jacks are almost always positive tip. I think you are best off using a 9VDC supply. If the voltage is not staying constant at 9 volts it could certainly do damage. If the supply you used was a negative tip positive sleeve you may have burned out a component or two...and more voltage than recommended could have done some other bad things. If it does not work with a 9VDC supply with the correct polarity you can fix it yourself if you have electronic experience. You could also send it to me and I'll fix it at a reasonable rate.
Aug 26, 2009 | Ibanez Ts808 Vintage Tube Screamer Reissue
Completlly stop working after wrong polarity lead been plugged In
one of the first things that go are is the protection diode coming off the + input. Then a fuse and so on. Surface mount fuses are light in color (usially green with white text). Attempt to bypass these components with a small wire or paperclip. Once you follow the lead from positive input you will run into a black rectangular block about the size of a grain of rice with 3 leads. That will be your voltage regulator. Its set at the correct voltage, and since you already have a power supply with a set voltage, then you dont need it. Its also the first thing that blows when you switch polaritys. (voltage regulators have 3 pins - input output and ground) when you switch polaritys that ground becomes the "input" and ..... go to all http://www.alldatasheet.com/ and type in the text you see on that component. It will then identify the component and list its voltage output and at which pin.  Apply set voltage to lead and ... pray?
Best of luck.
May 25, 2009 | Panasonic NV-DS60 Mini DV Digital...
BEFSR41 power supply?
Both the voltage and the polarity should be printed on the case of the router. The polarity should be right next to where the power plugs in.
The polarity information will look something like this:
If you take the router into a local Radio Shack, the clerk will probably be able to tell you which power supply you need.
Jan 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Maxtor personal Storage 3200 Power Supply [K01PWR3200]
i own the exact same drive. i'm looking for a spare power supply, came across this website, and saw your problem. the power supply is 12 volts dc at 2 amps. the connector that gets plugged into the hard drive: center pin is power (positive) and outer "shield" is ground (negative). hope this helps.
Dec 29, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Altec Lansing inMotion iM310 Portable Speakers for iPod  Logo
95 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
