Question about Lands Phones
Panasonic KX-TGA181NZ Cordless Phones - we have just noticed on both phones above the Signal on the Left Side there is a Face with Voice coming from it - never seen it before. Help Please
  • Anonymous Jul 24, 2008
    Can not even find the button to record answering message! Not very user friendly. :(
SOURCE: panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
Posted on Apr 18, 2009
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
SOURCE: Range extender for cordless phone
Ours behave similarly. The solution is to position the "base" (one connected to the phone lkine physically) in the center of the home so that the limited range can reach the remote phones at the periphery.
These phones operate at 1.9GHz. At that microwave frequency radio signals do not penetrate walls and floors very well. 2.4 GHz phones suffer increased "path loss" and are no better. The solution for any of these microwave phones is more transmitter power, which is illegal.
900 mHz phones actually work better because at 900 MHz nature offers less signal path loss", but try to find them in stores! For the same transmitter power level a 900MHz phones will have noticeably greater range.
The 1.9GHz D.E.C.T. phones also operate differently from other types of cordless phones and I believe that also contributes to dropped calls and the phone's inability to ring when a call arrives. At the fringe of its range you can see how it struggles to establish a link. Once established it will work well and then simply drop the call when you least expect. I am not a fan of the DECT phones, but they do not interfere with 2.4 GHz wireless routers, etc.
Posted on Sep 13, 2009
HelleP531
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
Posted on Feb 11, 2010
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
Message light flashing with all messages deleted
This is probably the Voice Mail Warning Indicator
(VWMI) which alerts you to messages waiting in
your telephone services' Voice Mailbox --- this is totally
separate from the cordless phone's answering machine
and is prone to 'key on' even when you do not subscribe
the telephone services' voice mail.
You can download a copy of your phones manual from
http://www.manualslib.com/download/303942/Panasonic-Kx-Tg9331t.html
( be sure to ignore the advertising large button
"start download" and use the smaller button "download"
across the top banner "downloads" "table of contents" etc. )
then enter the security-codes & select 'download pdf'' etc.
Try the section on page 39-40 about Voice Mail Service.
To summarize, Turning VM signal detection on/off:
The default setting is "On", To turn this signal "off":
1. press [MENU] # 3 3 2
2. scroll up/down to desired choice
3. press [save] [off]
May 07, 2016 | Panasonic KX-TG9331T Cordless Phone
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How Do I set up my voice mail on a panasonic KX-TGA410C
The KX-TGA410C is just the cordless handset. It goes with a base station and, presumably, an answering machine. What model answering machine would you like to set up?
Nov 17, 2013 | Panasonic KX-TGA101S Cordless Handset
I have a panasonic model KX-Tg2267 cordless phone with answering machine How do I retreive the voice messages?
Hi These 3 steps should help.
  1. Press the "HOLD/Function/Clear" button
  2. Scroll to "Programme" using the up and down buttons,
  3. Press the Play button
Jan 14, 2011 | Panasonic KX TG2267 Cordless Phone...
I purchased a panasonic digital cordless answering system. When I am talking on the phone and a call is coming in it does not go into my message box. the incoming call just continues to ring. I can hear...
You don't mean the "message box" on your answering system do you? You only get one conversation at a time. If you're talking to someone, how can the other conversation get to the mailbox?
Most people get central office based voice mail. Now they get a call waiting signal with caller id and if they ignore it, it's answered by the CO voice mail system.
Carl
Oct 06, 2010 | Panasonic KX-TG1033S Cordless Phone
Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Jul 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic kx-tg2357
Called Panasonic Support. The unit will NOT record voice messages whilst in talking mode.
Jan 06, 2009 | Panasonic KX-TG2357 Cordless Phone
Reprograming my voice message for incoming calls
hi
you can get a downloaded manual from here
http://theusermanualsite.com/manuals/mfg/panasonic/panasonic_kx_tg2257_kxtg2257.html
hope it helps
riz.
Oct 25, 2007 | Panasonic KX TG2257S Cordless Phone...
Lands Phones Logo
659 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
