Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
I can't get my pilot light turned on. I have a Rheem powervent water heater and I can't turn it on. I keep getting an error message that says "FVD interface failure/miswiring". What do I have to do to get my pilot light turned on??? Please help.
  • 494 Answers
Most likely your flame sensor wiring is partially burn't or has an open circuit fault that's giving you the error message. This wire starts at the gas control and ends next to the pilot assembly. It can easily be replaced using a small wrench to unscrew the end connector from the control and the flame sensor rod at the pilot assembly. Call Rheem and see if the water heater is still under warranty, but even if it isn't they can most likely order the part you need for you. The phone # is on one of the data decals on the side of the water heater tank. They will need the model # and serial # to order the part. Be sure you unplug the unit before working on it! Douglas
Posted on Sep 28, 2010
Pilot doesn't stay lit
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Replace gas control valve.
Mar 02, 2013 | Rheem Water Heaters
Does the vent motor come on when you turn on a powervent hot water heater
`1) Copy following link to troubleshoot by type of gas control valve, blower motor links, pressure switch testing, and other professional resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Power-vent blower motor can go bad.
Plug motor directly into outlet, or turn on-off switch on, and see if motor works.
Check outlet for correct polarity, and for at least 80% of rated voltage.
Check vacuum switch. Blower creates vacuum, and the vacuum switch detect vacuum, and signals gas control valve that burner sequence can continue.
Gas control valve can also go bad. Wiring etc can go bad.
Feb 04, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
40gal richmond powervent wont light. code says fvd interface failer what does that mean????????
sounds like the circuit board is bad,, when you turn on the unit does the fan come on first if not you need a circuit board, depending on the age it might be cheaper to change the whole unit
Jun 13, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Rheem water heater pilot light goes out
REPLACING THE SPARK IGNITOR WOULD BE MY FIRST GUESS .
Feb 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
562 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
