Display is dark
I have a toshiba 100CS laptop and when I power it up it has a dark screen. I went to the Toshiba site http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
and it has different was to reset this but if I can't see whats on the screen how do I know if it is reset or not? It mentions reloading the video driver but how will know if it reloads?
Thanks, Sid
    President:
  • 2,351 Answers
That was the correct Toshiba site but to find you're notebook I also need to know what ( Family )? EX: Family = Portege?
Read through these suggestions for you're Toshiba. Click on the link below. See if any of these help you.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb8&url=&dialogID=38560404&stateId=1%200%2038556986
Mike
Posted on May 25, 2008
Does anyone know if a Toshiba 100cs Satellite laptop is capable of connecting to broadband?
you could try a USB adapter Or PCMICIA card but it's a pretty old laptop, don't know if the drivers would be compatible. Good luck
Mar 15, 2011 | Toshiba Satellite 100CS PC Notebook
Toshiba Satellite 105A screen too dark to see password box
have you tried the F5 key?
On a lot of laptops that toggles the video output between the laptop display and the external display connection (socket on rear of laptop).
Cheers,
Steve
Apr 09, 2010 | Computers & Internet
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
The screen on my Toshiba satellite p205 went dark on me i check and u can see the window but really dark i replace the lcd screen and the problem persist help please what can the problem be my video...
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 24, 2009 | Toshiba Satellite P205-S7806 Laptop
Toshiba Satellite a45-s130 screen has gone real dark need a flash
Paul, Georgiana and You, 1. do you have an antivirus installed on your laptop? if not, then install one rightaway. 2. also from start->control panel->system->hardware->display adapters and monitor. uninstall the display adapters and reinstall them. similarly uninstall and reinstall the monitor drivers. 3. go to http://www.drivershq.com/Drivers/Toshiba/Satellite/A45-S130/4183/9941/10606/Drivers.aspx you will find here a driver detective that can detect your driver problems. try with that. 4. on the site above you will find drivers, for you to download and install on your laptop. if you still have problems, then you have
Sep 02, 2009 | Toshiba Satellite A45-S130 Notebook
My lcd is dark
If your battery and power suplly are ok, then you have a problem with your screen inverter, or needs to adjust your screen settings. Cleck display settings at your control panel
Feb 11, 2009 | Toshiba Satellite 1805-S204 Notebook
Info you asked for
Hi Sid, I can find information about the notebook but am unable to find any type of support from Toshiba. This includes drivers & possible bios files.
TOSHIBA PA1217U-S2W P75MHZ SATELLITE 100CS 8MB 500HDD 1.44 MB FDD
http://www.toshiba.co.jp/about/press/1996_02/e0101/e0101.htm
The lin above & below only show specifications.
http://www.ciao.com/Toshiba_Satellite_100CS_P_75_MHz_10_4_DSTN__15177839
Since you can not see anything on you're display, the back light may be defective & may need replaced. The goal here at FixYa is to help you find a fix. With that in mind can I suggest you click on this next link that will take you to a friend, here at FixYa. He has more experiance with notebook repairs than I.
http://www.fixya.com/users/benimur
Click the ask me button under his name & re-post you're question/problem. Benimer is pretty good with faulty display screens.
Mike
May 26, 2008 | Computers & Internet
Toshiba M45-S331, Black screen
I just went through all this myself. First I had the inverter replaced ($200) and it worked great for a week, then the screen went out again. It turned out that the LCD needed replaced ($200 more, labor comped from the first no-fix). There's a problem with the Toshiba LCDs that makes them burn out sooner than other brands. Since the replaced screen, no problems (2 months). Sucks, I know.
May 07, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Laptop Dark screen-cant really see it!! help!!
sounds like your inverter is gone. The inverter supplies voltage to the backlights of your lcd.
Mar 25, 2008 | Toshiba Satellite A70 Notebook
Computers & Internet Logo
178 people viewed this question
David Payne
David Payne
