Looking for manual for atwood mobile furnace model #7920-11
2 Suggested Answers
  • 68 Answers
SOURCE: ATWOOD MOBILE FURNACE RUNS WHEN IT WANTS/
Check your furnace for power. will be 4 wires. power ground and 2 thermostat wires. Check for power at the time delay relay, if you have power there check for power going in the fan motor, if power in motor wire, motor is bad. If no power in motor wire and power going to circuit board take the 2 thermostat wire apart and wrap the 2 together comimg from the thermostat. Fan will stat in about 30 seconds. If it does you need a control kit in the ac. But sounds to me like you have a furnace problem.
Posted on Mar 19, 2009
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Where do I find an owners manual for 1994 cobra seirra 5th wheel ?
THERE SHOULD BE A RESET BUTTON ON THE UNIT,YOU COULD TRY THAT OR GO TO ATWOOD.COM FOR SCHEMATICS,CHECK FOR MODEL #S FOR THAT YEAR .THESE UNITS HAVE NOT CHANGED MUCH IN MANY YEARS .IF IT DOES NOT WANT TO LIGHT ,LOOK IN THE TUBE OF THE UNIT FOR DIRT DOBBERS THAT MAY CONSTRICT THE FLOW OF GAS.THE RESET IS USUALLY BLACK AND NOT VERY VISIBLE,GOOD LUCK,HOPE IT MAY HELP
Dec 13, 2013 | RTO Atwood Water Heater - 6 Gal LP
2006 5th wheel atwood excalibur xt model 2334 furnace will not ignite
i assume spark igniter. check all connections with power off ! spark igniter gives a good jolt! probably electric board LOOK FOR FUSE ON BACK OF BOARD.
Nov 06, 2013 | Dryers
Rvp thermostat
After you replaced the batteries, you also need to sync the remote with the receiver for it to work again. Here's the manual link: http://www.atwoodmobile.com/manuals/furnaces/MPD%2033179%20SP%201.08.pdf
Nov 02, 2013 | Atwood Excalibur 8500 IV Furnace
How do you install circuit board in atwood furnace 8525? do I need to disassemble most of the furnace to do this?
I am not familiar with the model number. I have worked on all types of equipment and have never seen a system that required major dis-assembly to replace a board. What does it look like from the outside? Up flow furnace, through the wall with a split condenser, horivontal residential? Tell me what you can and l"ll probably be able to tell you exactly where and how. Thanks for trying Fixya.
Sep 11, 2013 | Heating & Cooling
Can't light oven in Wedgewood caravan oven
Do you have manual for proper lighting procedure? Do top burners have good flame?
Feb 27, 2013 | Atwood Mobile Products Atwood Wedgewood...
Atwood 7920-11 furnace will not light. I am trying to light the furnace on my 2006 Jayfeather 19H camper that is an Atwood and looks to be an automated pilot lighting system but I continually get a flame...
Your electrode acts as flame sense as well. Remove electrode and clean it thoroughly/carefully especially at end where flame would be sensed and retry. Be sure connections on high tension wire is good and clean as well as connector and contacts on circuit board as well. If still same result, replace electrode.
Oct 05, 2011 | RTO Atwood Water Heater - 6 Gal LP
Heating & Cooling Logo
245 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
